Question about Devilbliss DeVILBISS Devap DVH2600 Gas-Powered Pressure Washer
I have a hoda pressure washer it stats right up and while i was cleanning the wood fence i let go of trigger during about 10 min, and the motor started dying i pulled the trigger and it pick right up again any ideal what would make that do that? but one time i let it quit and i couldn't get it started,i had to wait about 5 min. then it started back up again.thanks
  • mike Jun 01, 2010
    model dvh2600
  • 364 Answers
A couple of things, what makes the engine change tone and revs is pressure, depending on the age, it may have excessive calcium build up in the pump, there may have also been a build up of crud or a wasps nest in the end of the hose when you connected and is now in the actual pump, you can remove the base and flush the sytem, hope this helps the problem, good luck.
Posted on Jun 01, 2010
Hoda power washer low on pressure
Caused by either of two things: The pump is worn and needs to be rebuilt or replaced. OR the pressure relief valve ( protects the motor from excessive pressure build up when you turn spray off) , is stuck in the open position thereby not allowing pump to build up pressure .
Apr 04, 2013 | Honda Garden
My dad's old craftman table saw will not cut straight. I put a new carbide tipped blade in to try to solve the problem with no luck. the wood is cut narrower in the center and it won't stay tight against...
Your problem could be one or more of... 1- Check to see that the motor mounts are secure and the motor is not moving around. 2- Check the shaft that holds the blade for the same problem if the blade is not directly mounted to the motor. If there is any "give" in the above two ways the blade could be held in place, corrections must be made to secure the blade so that it does not "wander" during the cutting procedure. 3- Be sure the fence you are using to guide your wood is set as parallel as possible to the blade so it does not cause the wood to follow another line once the wood being cut goes beyond the cutting blade. There is most likely an alignment procedure you can run through.
Sep 14, 2010 | Garden
High pressure won't return when triggered
If you unplug the tip, will it work? If so, unloader valve is sticking.
Jul 06, 2010 | Karcher 2500 PSI Pressure Washer
Wood feels like its "pinching" between blad and fence
Possibly the problem is the wood itself. If it is burning both sides of the kerf then it is probably that your kiln dried wood is picking up moisture on the outside from the environment which causes it to bow inwards as it passes the saw. I have even had this problem with plywood. Just keeping timber in an unheated workshop for a while can cause the problem but after a few months it should equalize and the problem disappear at about 15% moisture content. (kiln dried timber should be nearer 10%)
Cut part way along a plank and then mesure the kerf at the end of the plank and at the front of the cut. if it is significantly narrower at the plank end then that is your problem.
These hard woods you mention are always a problem to cut on domestic saws at usually a maximum of 2000 watts . I use a 4500 watt motor in my saw and it will still complain at dry oak, ash and maple etc. especially if they are moving a bit as I cut them. Before I retired I had a panel saw half as powerful again as that and still those hard woods could cause trouble.
Jun 01, 2010 | Craftsman 10" Table Saw
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
No high pressure no leaks motor runs off and on when trigger is released
check filter in wand and clean out nozzle hole for starters
May 04, 2009 | Garden
Biesemeyer fence not parallel to blade.
Yes you can adjust the angle of the fence. There are two adjusters at the front of the fence where it meets the fence rail. Adjusting these will pivot the fence either slightly left or slightly right.
There is a basc video on youtube my daughter made to show you how to align yourfence to the saw blade.
Feb 28, 2009 | Delta Machinery 3 HP Left Tilt Unisaw with...
Kracher k3 97, low pressure
your pressure relief valve is stuck open. try adjusting the nut shaped stem on the front of the valve to see if you can unstick it. if not you'll have to take apart and clean.
Jul 13, 2008 | Karcher 2500 PSI Pressure Washer
Devilbliss DeVILBISS Devap DVH2600 Gas-Powered Pressure Washer Logo
225 people viewed this question
Top Devilbliss Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Devilbliss Garden Expert? Answer questions, earn points and help others
