Question about Velodyne CHT-12 Subwoofer
Velodyne Hgs- 15x
I own a velodyne Hgs- 15x. I am trying to replace the driver. I have removed all the screws and still unable to get the driver removed. Can someone please tell me what to do in order to remove the driver?
  • 124 Answers
The driver has a soft foam rubber gasket behind it. It can act like glue on the driver.
Taking the driver out will tear up this gasket, always does, so don't worry about that.
You can try to lever the driver out. Use care not to scratch the baffle.
Posted on Jan 04, 2009
Is replacing an amp on velodyne sub a diy project.
shoudn't be too difficult if you can find a replacement amp that will fit in the case
Mar 14, 2011 | Velodyne HGS-10 Subwoofer
I have velodyne hgs15bg powered sub.. After a prolonged hard run, it developed a rattle at mid to higher volumes. what went wrong ??
You possibly ripped the woofer cone or welded the voice coil - something mechanical. There's only one thing in there that moves on purpose.
Mar 03, 2011 | Velodyne HGS-15 Subwoofer
Hello I have a velodyne hgs 12 I'm extremely happy with but over the years it has had some abuse and I think I finally blew the speaker. I was curious if I could find a replacement for just the speaker and...
Try www.partsexpress.com. You may find an even more capable driver than your original if you read the full specifications of the driver sizes that will fit the cabinet. Factor in your cabinet volume, amplifier RMS and peak wattage and you'll likely find what you're looking for.
Feb 18, 2011 | Velodyne HGS-12 Subwoofer
No sound is produced
No output could be an amplifier problem
You will need to contact Velodyne for service
Dec 27, 2009 | Velodyne HGS-10 Subwoofer
I have a 2002 Velodyne SPL10BV. I used to leave it on all the time because on auto it would cut out. It would come on late when watching a movie. Like the signal was delayed to the sub. Now the sub...
The problem is in the amplifier section.
This sub uses the same amp the HGS units have. The pre-amp is a lot like the HGS units as well.
The only place you will find to service the unit will be Velodyne.
My guess is that you will need to send the amp section to them.
It is easy to remove, just make sure to mark the speaker leads before you remove them.
For the auto on function.
You may have a low signal to the sub.
If your source has adjustments for the sub output, try setting it up a number or two. Then use the volume control on the subs amp to mach your main speaker volume.
Dec 19, 2009 | Velodyne SPL-1000 Subwoofer
I just bought a used Velodyne hps 18 subwoofer. I am hearing popping sounds even at idle. What might be causing it?
This is related to the "servo control" circuit.
For repair you will need to contact Velodyne.
Nov 16, 2009 | Velodyne HGS-18 Speaker
12 blown velly
If you have an HGS unit, the only source for a replacement speaker is Velodyne.
You will need to contact velodyne for the price.
Oct 28, 2009 | Velodyne HGS-12 Subwoofer
SPL8R Velodyne sub - Same probelm
Go to the Velodyne web site and check the service center locations.
They may have one in your area.
It sounds like the amp may be the problem. That may be all you need to send.
Best bet, Contact Velodyne.
Jun 08, 2009 | Velodyne HGS-10 Subwoofer
Velodyne subwoofer HGS12
Not able to help you in Brazil
Contact Velodyne via their web site
Jan 15, 2009 | Velodyne HGS-12 Subwoofer
Velodyne CHT-12 Subwoofer Logo
275 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
