Question about Harman Kardon AVR 100
Harman Kardon AVR 100:Power button stays red when pressed manually or via the remote. It clicks, goes orange for a split second and back to red. No info displays in front panel. Can you tell me of a solution to problem. Has been very dependable. I've had the unit about 7 or 8 years. Thanks,
    President:
  • Harman Kardon Master
  • 1,114 Answers
The most common problem found on FixYa for Audio VideoHarman Kardon AVR 100:Power button stays red when - 2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 03, 2010
2 Suggested Answers
jonsen
  • 62 Answers
SOURCE: harman kardon avr 100 no power
check the fuses it help the power !
Posted on Jun 10, 2010
HOW TO RESET HARMAN KARDON AVR70
Hi, Try this. Hope this helps and I have the link here to the manual.
Processor Reset
If the AVr behaves erratically after a power surge, first turn off the front-panel
main
power switch and unplug the Ac power cord for at least 3 minutes. plug the cord back
in and turn the AVr on. If this procedure doesn't help, reset the AVr's processor as
described below.
note: resetting the processor will erase all user configurations, including speaker and
level settings, and tuner presets. After a reset, reenter all of these settings from your
notes in the Appendix worksheets.
To reset the AVR's processor:
1. press the front-panel Standby/on switch to place the unit in the Standby mode (the
Standby Indicator led will turn amber).
2. press and hold the front-panel Standby and memory/folder buttons until the reSet
message appears on the front-panel message display.
3. press the memory/folder button again to reset the AVr's processor.
If the AVr does not function correctly after a processor reset, contact an authorized
harman
kardon service center for assistance.
to locate an authorized service center,
visit our web site at www.harmankardon.com.
https://www.harmanaudio.com/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw409ee4c9/pdfs/AVR700NEW_OM_EN.pdf
Jul 28, 2016 | Harmon Kardon Harman / Kardon Avr 70...
HK 3370 power button turns red when pressed device will not turn on
There may be a short on the output side. Try disconnecting all the speakers on the back of the amp. If the unit stays on after that, turn off the amp and carefully reconnect one speaker at a time. Try turning on the amp after each reconnection. This might isolate any shorts that might exist.
Nov 09, 2013 | Harman Kardon HK 3370 Receiver
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
How to reset the recever?
Place the receiver in Standby mode (press the front-panel Standby/On Switch so that the Power Indicator turns orange).
Then press and hold the front-panel OK Button on the Receiver ( not remote ) for at least five seconds until the RESET message appears in the display. Then press OK. The system will go to factory default. All your settings will be lost like FM stations / Sound settings etc: .
Apr 03, 2011 | Harman Kardon AVR 35 Receiver
Harman kardon avr 100 no power
Jun 07, 2010 | Harman Kardon AVR 100
My Harman/Kardon AVR 140 is stuck on stand by mode
I have the same problem on my AVR 1550 - its been bugging me for ages then it works again, then it doesn't ...
Aug 28, 2009 | Harman Kardon AVR 140 Receiver
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
Harman Kardon AVR 100 Logo
210 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
