Question about Alpine TDA-7547
I dont no how to connect wiring for alpine stereo model tda 7548e
  • 364 Answers
Theres a standard amongst most stereos, so if these colors apply, then you will be right,
Red is Ignition power
orange is direct power
Black is earth
blue is for phone
White is for electric arial
then there will be four coloured wires with matching color trace wires, these are the speaker wires.
Hope this gets you going, good luck.
Posted on Jun 01, 2010
How do you activate the AUX function
This unit should recognize the connection between the deck and the changer without any problems. Are you sure the plug is compatible with alpine unit?
Sep 09, 2013 | Alpine TDA-7554
I need a wiring harness for an old model Alpine TDA-7547
You can get one from pacparts.com or any decent car audio store. The part number is AL16-0001.
Dec 03, 2012 | Alpine TDA-7547
Car stereo wired to battery and fuse box what wires go where
If this is an aftermarket stereo, The red wire needs to go to a power source that turns on and off when you turn your key on and off ( a fuse in the fuse box ). The yellow wire needs to have power all the time like its connected to the positive battery terminal or a fuse in the fuse box that always has power and the black wire is the ground and needs to be grounded to the negative battery terminal.
Oct 22, 2012 | Alpine TDA-7563 Cassette Player
Am wiring my alpine car stereo back to my old car , unfortunately i dont know were to connect the wires , the labels on the wires somehow got cut when i kept it in storage , need help figuring were the red...
First thing you will need to do is to buy a wire adapter for your specific make & year of car. This interfaces the stock wiring plug allowing you to connect the wires from the headunit to the wires of the plug.
Here is a color coding explanation for the wires on your Alpine Deck:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
Mar 17, 2011 | Alpine TDA-7563 Cassette Player
Removing alpine receive from dash
Unless you have the 'keys' that came with the unit, you'll need an Alpine dealer to a) get keys so you can remove yourself (wiring just un-plugs) or b) installer. CStereo mfgrs use different snap-lock mechanisms and sometime different keys for different models.
Apr 21, 2009 | Car Audio & Video
Alpine TDA 7563 loses presets when vehicle is
You don´t connect correctly the wire for the constant power suply that´s why the memories don´t stand still,always be a yellow one you need to connect to a direct power suply,good luck
Mar 14, 2009 | Car Audio & Video
How do I preset the stations for an Alpine TDA-7547 car Stereo. This is an older stereo and setting the stations is not intuitive.
Select the station you want. Then hold down one of the 6 preset buttons for a couple seconds. When the station ID flashes, release the button and it should be saved.
Dec 06, 2008 | Alpine TDA-7547
Wiring diagram
Red: voltage source controlled by the ignition key Yellow: constant voltage source Black: ground Blue: power antenna activation wire (if equipped) Blue/white: amplifier activation wire (if equipped)
Jun 06, 2007 | Alpine TDA-7563 Cassette Player
Car Audio & Video Logo
321 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
