Question about LG LHT854 Theater System
How to hook up the componet cables to the tv so i can watch dvds using the dvd player
    Brigadier General:
  • 8,546 Answers
Just hook up the audio best available DVD (or any) to this unit and the video directly to the TV. Running video through an HTS may add simplicity but it also adds two connections that could be points of failure or produce distortion, voice sync problems, etc.
Posted on Jun 01, 2010
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
Jul 11, 2015 | Samsung Audio Players & Recorders
My Panasonic viera TX-26LXD70 says that there is no DVB service found and to check my aeriel or Local DVB service availability. There is no socket to put the co-axial cable in the tv. The tv still works...
Use HDMI from the DVD player and hook up the antenna to the TV..... or DB9 connector on TV.... DO NOT watch DVD from a D VD player or compost cable from the DVD it looks like junk. consult manuel how to hook up your TV
Feb 27, 2014 | Panasonic Televison & Video
Cant get DVD to play how do I hook it to my TV
depends on the tv and dvd player. old dvds you plug in the cable with three colors. red white and yellow to the tv input of the same color. now a days dvds and flat screens use the hdmi cable.
Dec 04, 2013 | Audio Players & Recorders
I dont have cable.i was using this tv just to play dvds and i accidentally hit channel search. now i get a blue screen that says" plerase connect cable system or an antenna to the terminal on the back...
Hi:
Using remote locate a button called tv/video or Input, turn on the DVD player and hit this button until you see your DVD player Logo. Most dvd players use either video 1 or 2, or componet or HDMI outputs. Seems you have changed the TV's input back to TV mode and you need to change it to a video mode input.
May 17, 2011 | Televison & Video
My sony BDP-s550 has a green tint to all dvds we watch. I already tried resetting to the factory settings with no success.
Just another thing to check that may take a few seconds.. Are you using componet video cables on this dvd player? If you are, check that all 3 video cables are plugged in, you may even want to unplug the cables and plug them back in. If you have a spare componet cable try that as well to make sure it is not a cable issue. I have been to many homes where just 1 of the 3 componet cables was just unseated or had a broken cable.
Mar 08, 2011 | Sony BDP-S550 Blu-Ray Player
Hook up
Hi:
This type of hook up is only for television viewing, to view the DVD you might consider purchasing some componet cables, they are color coded so hooking up is a snap, on the back of the DVD player you will see three RCA type connections Red/Green/Blue. componet cables are also these colors, connect one end of the cables to it coorsponding color on the back of your DVD and the other in the same color connectors labeled componet 1 input on the back of your television. You will also need a red and white RCA connector also for the audio as this is sound, a total of 5 connections will complete the hook up. Or you can go the simple route and use RCA type cables that come as yellow/red/white but for the best picture use componet cables this will allow you to watch your movies in HD.
Apr 27, 2010 | Sylvania Dual Deck DVD/VCR
Can't see dvd on TV
how to hook up to watch dvds
May 25, 2009 | Sansui VRDVD4005 DVD Player/VCR
I just got a Toshiba 40" 1080p tv. Everything looks good except dvds are red tinted with no sound??? It is a standard dvd player (no hi-def) with component cables
Double check that your componet cables are in the correct colors on both the dvd and tv. Also what are you using to transmit the sound from the dvd player to the tv. Component cables are video only and not sound.
Jan 26, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
LG LHT854 Theater System Logo
143 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
