Question about KitchenAid KHMS2056S Stainless Steel 1200 Watts Microwave Oven
Says "Door open more than 5 minutes" when it hasn't
This has happened a few times before, but after a few hours, it fixed itself.
For no reason, when I tried to use the microwave, it wouldn't work and posted a message saying the door had been open for more than 5 minutes, so I needed open and close the door, then try again. I did that, and I get the same message, over and over again. I have tried everything, and nothing works. It's has been stuck on this message for over a day now. I can't unplug it, since it is built into my cabinets, and would have take them apart to get to it.
Any advice would be appreciated. Thank you.
If you cant unplug it just hit the breaker same thing as unplug
Posted on Sep 13, 2012
    President:
  • 1,902 Answers
You are going to have to replace the door switch. The switch is staying open even when it should be closed. Talking about electrical current. Once that part is replaced everything will work just fine.
Please rate
Posted on Jun 01, 2010
Microwave oven - switching on involuntarly.
Not to make light, but most broken items were sound at one point in time. With the price for new small microwaves running less than $100.00 it is likely not cost effective to repair unless there is a known easy fix.
Sep 10, 2016 | Panasonic Microwave Ovens
Opening the door tripped breaker a few times, now microwave will not power on.
Sounds like a bad switch should have three primary, secondary, and monitor switch after 5 years change all 3 they are not the same primary and secondary are NO ( normally open ) and the monitor NC ( normally closed ) unit will not come on the fuse on the filter board is blow this usually shorts out the filter board change the switches first and replace fuse may not have to replace filter board hopes this helps.
Apr 06, 2015 | GE Monogram ZE2160SF Convection /...
Whirlpool microwave turns on and have to open door to stop it
Has it got wet inside at all? If so it could sort itself out after drying out.
But I would keep leaving the door open as you do, or replace it. Because it is a safety risk, if it came on while empty, after a while it could set fire to itself.
Dec 19, 2013 | Microwave Ovens
I tried pressing and holding the STAR button for more than 5 seconds or so to unlock a goldstar microwave mv1526w but nothing happen i tried disconnecting it for over a 1 minute, try doing everything again...
follow this steps and fix it. God bless you
However after you did this steps go and buy it in www.repairclinic.com
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Oct 24, 2013 | Goldstar Microwave Ovens
Fan runs when microwave door opened
-You're already answer yourself.
Good luck
Mai
Jan 22, 2018 | GE JVM1650 1000 Watts Microwave Oven
Fan goes on when we open the door. Goes off when we close the door. Any fixes?
This is a malfunction and must be checked to confirm if the microwave itself is working when the door is open which is dangerous. The reason can be due to a short in the door lock switch or a mis-alignment of the door switch. Also a malfunction of the main board, relay cannot be ruled out.Remove power and close the door with a gentle force , few times so as to disengage any lock switch defect. now try if the fan cuts off or else it is best to take opinion as you will need to disconnect the HT section to check this fault to prevent any stray microwave.
Nov 30, 2011 | Frigidaire PLMV169DC Microwave Oven
Odd buzzing after timer stopped, food was still being heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r6uw
Aug 20, 2009 | Whirlpool MH1150XM Convection/Microwave...
Microwave comes on on its own. What can be the problem?
I suggest you see a repairer but until then when ever it's not in use leave the door OPEN
Kind Regards,
J Howard
FixYa Operator
Dec 28, 2008 | Frigidaire FMV156DC Microwave Oven
When the oven is cooking for over 5 mins part of the door goes a white opaque colour inside the door, it is as if the seal is broken and steam is getting inside the door itself.
That's probably what's happening, but it's not dangerous as long as the internal cooling fan is running and the screen / mesh between the door panels is not arcing or rusting.
It's suggested that you leave the door open for a few minutes any time you cook and notice a moisture buildup afterward.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 20, 2008 | Panasonic Microwave Ovens
Runaway microwave oven
I'm wondering how old this is? There should be a date on the model number tag, or an FCC IC number on the label I could look up if you can supply that. You may have a defective control panel assembly. We routinely repair these nationwide for $32.50, but I'd be interested in how old you think this is. Does it do this when the door is open? I really doubt that it's actually cooking when it comes on, but it is possible. If the door is open, that should prevent it from happening. Only a temporary stop gap, though. Another way to find out if it's really cooking when it comes on is to place a cup of water inside. After it has run by itself a couple of minutes, check to see if the water is warmer. Besides the control panel, it might be the upper door switch or mount. You can do a Google search for my text file "doorsw.txt" which gives you good safety info and tips on how to check and replace defective door switches. Let us know what you find.
Oct 17, 2006 | GE JES1039 Microwave Oven
KitchenAid KHMS2056S Stainless Steel 1200 Watts Microwave Oven Logo
79 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
