Question about Dell XPS 420 PC Desktop
Is there any additional cable to run between the monitor and the tower with a build in webcam
    President:
  • 623 Answers
That does not depend so much on the computer but more on the monitor you have attached.
Often monitors have a separate USB connection to the computer to enable external USB ports. If your monitor has such a connector, I would definitely use it - look also in the manual for the monitor itself.
The cable usually used by Dell looks like this:
The VGA or DVI cable send only signals FROM the computer TO the monitor, so you will need another connection, if you want to use you webcam.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Jun 01, 2010
Emachines el1200 will not start up. When power button is turned on...it will blink shortly after ( no beeps ). It will not turn on monitor
As mentioned that when you turn on the system the lights on the system turns on and the monitor goes off, unplug the VGA cable from the system tower and turn on the monitor and check if you get signals on the screen if it shows you some color bar or a massage, that means your monitor is good. IF not then there is problem with the monitor . get it repaired or replace it. If that is not the case you would need to unplug all the external devices connected to the tower and try, IF not then you need to open the tower and check for the green light on the motherboard if it comes on or you can try reseting the memory card or if you have an video card, then you will have to remove the card and try the build in one .
Regards
Samson ved
Oct 21, 2013 | Computers & Internet
What cable do i need to connect my cam from my monitor to the tower
I'm assuming you mean webcam, if so you will need a USB cable to connect that. If not you would need to put information about this "cam."
Feb 28, 2011 | Dell E228WFP Monitor
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
It is turned on but screen stays black once tower is powered up.
we need to make sure whether its a Tower problem or monitor Problem>
Do this simple test> Disconnect the Cable that connects the Tower to the Monitor(while the tower and the monitor are on)> then see if you have any error msg on the monitor screen> if you have someting that says "Chk video cable" or " no signal"
Ur monitor is fine and the tower is faulty> IF not thn ur monitor has gone bad>
Oct 20, 2009 | HP 75 17 in.CRT Conventional Monitor
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
Was searching the web and screen went black,,power light is on but no screen,,no menu screen,,cant hit auto seek,,nothing,,to me seems like the tube is blew out,,any suggestions?repair price?
whats the light on the towere if the light is stedy green then the tower is ok so unplug the data cable from tower and turn on the monitor then if it run the self test then monitor is ok if its not yiu need to repair or replace the screen
Jun 26, 2009 | Samsung SyncMaster 213T 21.3" LCD Monitor
Monitor to tower hook up problems
Open your monitor's cover and plug out vga cable and check continuity of wirs this way-d314a67.jpg
Mar 26, 2008 | Gateway FPD2275W LCD Monitor
Signal Cable Problem
Check the monitor plug that goes to the computer for bent pins. or try another monitor/or cable .
Jan 12, 2008 | Computers & Internet
Dell XPS 420  PC Desktop Logo
468 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
