Question about Optoma EzPro 739 Multimedia Projector
No Signal The projector works fine during windows start up, but once the desktop shows on the notebook you lose the picture on the screen. No Signal
    Genius:
  • 1,447 Answers
On your notebook press fn key and look for F# key that has a monitor or lcd picture on it( ex: F5 or F4). and press on it as well while holding down fn on keyboard
Posted on Apr 08, 2008
Laptop on, presentation loaded, projector funtioning and will show menu on projector screen but no presentation will display. What else do I need to do, please?
You may have to adjust the resolution your notebook is displaying at in order to make it compatible with the resolutions that will work with your scanner.
For example, most new notebooks display at 1380x760 or 1440x900, which are 16:9 ratios most suitable for movies.
Most projectors display at resolutions with ratios of 4:3, like 1024x768.
For Windows, right-click on a clear area of the Desktop and choose Properties... or Screen Resolution. Change the resolution to match your projector.
Feb 28, 2011 | Computers & Internet
When i power it on. the picture shows for about 5
losing the signal. reset the settings to factory default and replace the cable. make sure the resolution matches.
Dec 16, 2009 | InFocus ScreenPlay 5000 Multimedia...
Suddenly stops showing the picture
The cause is a sudden overheat but when restarted its fine then it goes again this intermittant issue is with the lamp beleave that or not i found replacing the lamp solved the issue perm.
Thanks and please leave postive feedback..
Nov 17, 2009 | NEC NP60 Projector
Projector works fine, but does not show video
Hey. Sounds like you are using some kind of dual-view or extended desktop via the computer for video. This may sometimes be a problem. If you can see the desktop but no video using the projector it is not a projector problem. It is probably your grapic card och software problem.
Try different setups in the graphic cards settings, like the projector as primary monitor etc. That usually solves the problem.
/Patrik
Jun 05, 2009 | Hitachi CP-S210 Multimedia Projector
I'm trying to usse my acer aspire one with an Hp sb21 lcd projector and it won't work. Any ideas? As the computer boots the projector shows the windows screen, but when it goes to the desktop, the...
You might have not enabled your computers second display.
This is actually a very nice feature, because you could run your powerpoint slide on the monitor while still running your normal applications on the laptop screen.
Go into control panel, display properties and then click on the "second" monitor (you could click on "Identify" to see which is which) and then select the "expand my desktop onto this screen.
The LCD display will be just a normal background, but you can drag windows from your laptop screen onto the LCD and back.
Hope this helps
Apr 19, 2009 | Acer Aspire One Netbook 8.9" Notebook
Laptop computer connected to projector.
When the projector displays the background image and the lcd displays the desktop as normal you can drag the open windows to the left or right and display them on the projector. it sounds like this laptop has an internal video card. If you right click on the desktop it might give you options to configure the display settings for the video card. Not sure how you will get to it if it does not show up on the right click menu. Probably through the start menu or in the control panel there should be somewhere to change the settings for the video card. This will no be under the display settings though.
But once you find your dual display options you will be able to change it to make both displays the same
Jan 21, 2009 | Dell Latitude D600 Notebook
The projector doesn't show what is on my screen
your projector may be on the 2nd screen or presentation mode of your video card. open an application and drag the application window off your screen (try both sides) and see if it will appear on the projector.
Jan 10, 2009 | Toshiba Satellite A15-S127 Notebook
"no signal " on the screen
After half a day of tinkering around with my new Acer I fixed my problem, which I think is yours also. I connected it to my notebook, it read the signal 'D-Sub' or something like that, and after my notebook finished startup, it reverted to no signal. I tried it with my desktop and it worked just fine. The display will only show up on one output device. It worked fine on my desktop because I was unplugging my monitor in order to hook up the projector. Hooking the projector up to my notebook left the display panel still active and that was where it displayed. In case I'm not making sense, the solution is this: After setting everything up, hit Control+Alt+F1 to switch display from your screen to the projector. To switch back, hit Control+Alt+F3
Oct 15, 2008 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
Connecting notebook to projector
Hi, it is possible that your notebook is set to a high resolution that your projector cannot handle. You may want to try to: 1) run your notebook as is (without connecting to the projector); 2) soon as windows booted up, right click on any clear area of your desktop and click on Properties; 3)Go to the Settings tab; 4) Set the Screen resolution to the lowest possible setting, towards left (less) and the Color quality to the lowest possible. Clilck Ok then reboot. Run once to see everything is OK except your icons are bigger now. Youo can try connecting your projector to see if it works. Hope this be of help to you. Cheers.
Apr 20, 2007 | Toshiba TDP-S8U Multimedia Projector
Open Questions:
Optoma EzPro 739 Multimedia Projector Logo
139 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
