Question about Dryers
I need to replace a simpson sirocco lint cover spindle Do you no where i could purchase one. the plastic casing on the spindle has broken and the lint cover will not stay on.
  • 159 Answers
I'm not sure where you can get one as i am in australia but an appliance spare parts outlet should have one or order it in for you,alternatively try simpson or electrolux.
Posted on Jun 01, 2010
Janome 660 sewing machine has broken bobbin winder spindle. I can order a new spindle, but cannot get the cover off of the machine. all screws are out.
You can purchase a stand-alone bobbin winder from the local fabric store (JoAnns or Hancocks) or Amazon.com for ~$25.
Dec 02, 2015 | Janome Jem Gold 660 Sewing Machine
Is it a big job to replace the heater element on the Simpson Sirocco 350 dryer?
It won't be the element unless a wire from it is grounding against the casing. You most likely have some sort of issue with the home breaker.
Mar 15, 2014 | Kenmore 500 6952 Dryer
Breville Model FP 1A Kitchen Wizz plastic sleeve for spindle
I have the same model -Breville Kitchen Wizz I have the bowls and blade accessories if anyone still wants them- I'm finally giving up on it even though the motor is strong the plastic casing is all cracked with age. Greta
Jun 13, 2010 | Food Processors
Simpson Sirocco 350 Dryer cuts out after 5 minutes I am told it is the heat sensor attached to the red button inside the door but not sure how to access the sensor to replace it.
Its probably NOT the sensor causing the problem. Have you checked the fan belt, that its not broken, come off the pulley or stretched? Put your hand over the airvent outlet at the back after it has been running a few minutes, if there is a lot of hot air coming out, then belt is ok. If not, replace the fanbelt with a new one, and problem will be solved. The sensor pops out because of overheating - usually because either the fan belt is broken or stretched, or the lint filter is blocked. Hope this helps!
Jun 04, 2010 | Dryers
I have a simpson eziloader dryer modal 39S500 the belt broke. i need a diagram on how to replace it. I also have to replace the bearing.
Hi I have a simpson eziloader 5kg Model: 39S500. I've just replaced the drum and put it all together but I have a spring that I'm not sure where abouts it goes can anyone help thank u
Mar 15, 2010 | Dryers
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
Diagram of how to replace drive belt on simpson sirocco 500 tumble dryer
May 12, 2009 | Dryers
Simpson Sirocco 350 Dryer not heating
I repaired my broken fan belt with a drop of super glue - there is virtually no load on the belt and it now works perfectly again. A 30 sec quick fix.
Mar 21, 2009 | Dryers
there is an oval cover on the back of the dryer. Remove this cover and you will probably find a broken fan belt. A replacement costs about $20 Aus.
NOTE: If you have been using the dryer for a while in this condition there will certainly be moisture inside the dryer. Replace the belt and leave the dryer for a few days to dry itself out (motor and electricals) before firing it up.
Oct 08, 2008 | Maytag 7.0 Cu. Ft. Electric Dryer
Dryers Logo
340 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
