Question about Panasonic PT-47WX49 47" Rear Projection Television
PANASONIC 47" WIDESCREEN REAR PROJECTION TV
My tv has got a oblong blue strip in the bottom right hand corner what has caused this and how can i fix it?
  • Panasonic Master
  • 8,617 Answers
Go to the convergence menu and see if you can see a clear Blue cross when you try to do a convergence. If the blue looks only like a blob of blue. then the coolant in the blue tube needs replacing. if the blue cross appears as a cross the convergence ICs are probaly weak. I would guess its the coolant thouh that model has a tendancy to trow a blue streak when the coolant is even a little cloudy. let me know if you need more assistance.
Posted on Apr 08, 2008
6ya staff
SOURCE:
I have a panasonic projection tv from 2001 the blue projector is ofset and the remote will only alter the projection up and down not left and right. This is causing a double imageof a blue outline
Very common problem caused by failed convergence IC. You can get the panasonic convergence repair kit for your model from www.tvrepairworld.com which has the ICs, resistors and the CD with repair instructions.
Mar 20, 2011 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
I have panasonic rear projection tv. There is
The PT53WX53 convergence repair kit available at www.tvrepairworld.com should repair that issue. The repair kit contains the parts and the CD with instructions.
Oct 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Green arc across bottom of tv,and a little purple.
Replace Both of your convergence ICs STKs, big black ICs.
Jun 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I have a panasonic 47" widescreen about 5 years old. Recently turned it on and all 4 corners are missed aligned and a faint line going through the middle. Tried setting the convergence with all of them...
Yes, the convergence output IC's have gone bad. They need to be replaced. This is a very common problem with all projection tv's. It is the job of those outputs to properly align where the red, green and blue beams land on the screen.
Jun 06, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Picture size won't fit screen. Can't see scrolling text at bottom (e.g. sports scores on ESPN)
hi there,
its probably not the tv but the set top box you need to fix. go to the settings and select the mode you want ie. widescreen 16:9 etc
then go to the tv and select the full mode or widescreen mode at 16:9
that should solve your problem. it takes some time to find the combination between the set top box and the tv to get it right
good luck
smeags
Dec 30, 2007 | Panasonic PT-47WX53 47" Rear Projection...
RED color wont converge with + PT-53WXD63
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 12, 2007 | Panasonic PT-47WX53 47" Rear Projection...
PT-47WX53 blue convergence
you will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
62 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
