Question about HP J4680 Office Jet All-In-One Printer
Hp j6480, Wireless blinking and exclamation point blinking only. No LED screen nor response but the scanner light bed is on when I lift up the try. Buttons do not response. Over all it does have signs of life. Working from a imac and PC.
  • 58 Answers
SOURCE: error light
it detected an error. try opening the paper tray to see if there are paper jammed. take out the the drum with powder and and turn off the printer. then put all back in place and turn on printer. usually the hp network printer is installed on the server. check on the server if you see on error from the hp driver program.
good luck.
Posted on Dec 06, 2007
SOURCE: Scanner Error - Power On > Power Off
saya mau tanya solusi problemnya
Posted on Aug 25, 2008
  • 310 Answers
SOURCE: HP Director buttons greyed out in Mac OS 10.5.4; scanner can't find IMac
Hi
Reinstall the software it will work..
For installation and scanner process u can refer the user manual.
Check this one
http://www.lavc.edu/IT/Manuals/Printer_HP_Laserjet_3380_User_Guide.pdf
Posted on Sep 08, 2008
SOURCE: HP F380 Scanner
Please click on the following link, the link will open up a document to resolve the blinking lights issue,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00859575&lc=en&dlc=en&cc=us&product=1128296&rule=21439〈=en
the below link is for the drivers for your printer, select the ur operating system on the ur computer and download the full feature software for free for ur printer,
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us〈=en&product=1128296&
Regards,  raj_p5983
Posted on Jan 23, 2009
wiqi546
  • 1511 Answers
SOURCE: I lost the install disk for my hp j6480
Hello and Welcome to FixYa!
Click on the following link and select your operating system to download your printer's software and driver.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&product=3635378&lang=&
Kindly rate me if i was helpful.
Regards,
Waqar
Posted on Sep 03, 2009
LED lights on my Kodak point of care CR-140 are blinking orange and getting a state stalled message when trying to load a film
Hi, have you called the company about your problem? Whenever there is a problem with a product it is a good idea to call the company that made it. I have a HP products, whenever I have a problem with it I call them and I get the help that I need. Try that and hope my advice helps.
Jul 22, 2014 | Office Equipment & Supplies
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
LinkSys WAP54G non-responsive...
upgrade the firmware and reconfigure it, still if it doesn't works then the router i faulty
Jan 23, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Ink light of my tx101 keeps blinking
Hello, Amit.
From FixYa, give this a try:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Hope this helps.
Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Lights are flashing on printer and it will not print . the voice says there is a problem with the printer. I did the alignment process but the voice keeps saying there is a problem. I took both cartridges...
There 3 light on the printer that able to indicate to user when problem occur. Which is the light u mean here?
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
YBC (/\)
Sep 28, 2009 | Lexmark X2500 All-In-One Printer
The amber lights are blinking next to the printer icons and exclamation points on top of the printer. How do i get that to stop so my print job can go through?
YBC (/\)
Aug 06, 2009 | Lexmark X2500 All-In-One Printer
Lexmark x2500
There 3 light on the printer that able to indicate to user when problem occur. Find your printer error accordingly as below and may solve your printer problem.
Hope this help.
YBC (/\)
Feb 05, 2009 | Lexmark X2500 All-In-One Printer
Sounds like the scanner has died. Sometimes restarting can help out. If you can print try printing out the configuration page and let us know what the error codes are.
May 27, 2008 | HP LaserJet 3380 All-In-One Printer
Power on,amber loight led on and no action
Exclamation light
The amber light in the shape of an exclamation mark (!) blinks when the unit requires attention. The display will give further information. The light is off when no attention is required.
Sep 25, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP J4680 Office Jet All-In-One Printer Logo
684 people viewed this question
Seeker5211
Seeker5211
