Question about Philco 841205 Turntable
Philco 841.205 Turntable Issues
The turntable won't work in my record player, I have checked and rechecked the belt and this is not the problem.. are there anymore suggestions as to what I could do?
THank you very much!
  • Philco Master
  • 5,318 Answers
I take it that it doesn't turn? OK two choices for you. Faulty motor, or a on/off switch that doesn't work. If you have to move the arm to start the turntable then some kind of leaver switch is either bent or broken.
I should imagine this model uses no more than a 12 volt motor. If you have no look with the switch, find the motor and take it out. Then stick a 9 volt battery on it, or lower voltage if it's only 6 volt motor. If it don't go it's bust!
Posted on Jun 04, 2010
  • 1 more comment
  • Joules H
    Joules H May 24, 2017
    Hi! How can I troubleshoot to see if the lever switch is bent of broken?
  • Joules H
    I have model 841.230 Philco Retro CD and Record Player with AM/FM Radio and I need to move the arm to start the turntable. Recently it stopped cueing the table to turn. Where/what should I look for to see if the lever switch is broken or bent?
  •  Grubhead
    Grubhead May 25, 2017
    You need to remove the underside of the turntable or get to it somehow. This should show you the works. When you move the arm towards the turntable you should see the connecting rods push on a switch.
My Philco 841205 Turntable spins normally, but
If this is a belt driven turntable then when the arm rests on the record the weight cause the belt to loose traction and slip around. The only cure is a new belt. Make a note of how the belt fits before removing as the biggest problem with belt turntables is knowing how the belt fits. When removed. Measure the diameter of the belt in MM and then the thickness. You won't need to be spot on with the diameter. Put the measurments into Google with the words turntable belt. Get the one that is nearest your measurements.
Sep 16, 2014 | Audio Players & Recorders
What can I do when the turntable is not turning?
You most likely have loos or broken drive belt. Look underneath the uni. you'll see if the belt is there or not.
Aug 10, 2014 | ION Audio Vinyl Recording Turntable
How install belt on philco 841 205 turntable
There are plenty of instruction videos on YouTube about belt replacement, look at a few of them, if you can't find the specific make of your deck.
Apr 04, 2014 | Philco 841205 Turntable
I have a Spirit of St. Louis turntable that won't turn.
This model of turntable automatically stops when the needle reaches the center(the end) of the record. The motor should turn back on if you move the arm to the far right of the player, past its resting spot.
May 02, 2013 | RCA Spirit Of St. Louis Radio/Cassette/CD...
My Crosley CR49-TA won't revolve. It turns on, and
Most turntables are belt driven. Suggest you take a look inside but remember to unplug the deck first. Usually it's a simple case of slipping the belt back on.
Apr 26, 2013 | Audio Players & Recorders
Detrola record player wont spin, even after moving arm to far right.
I suggest you lift up the turntable matt and see if you can see a belt, which has either broke or come off. You might need a new belt!
Mar 22, 2013 | Audio Players & Recorders
I have a Sony PS-LX250H that was put into storage and moved twice while I was in transit between residences. Since I got to my new place I haven't been able to get it to work at all even after rep
check the belt it might be loose...
elasticity of the belt is ... no more :(
try turning the plate by your hand and see what happens
Good Luck
May 09, 2017 | Sony PS-LX250H Turntable
On my Philco Turntable CD with cassette the CD player does not close all the way. If you manually close it, it does not play
You are describing too problems, won't close all the way, could be a bad loadind belt. the second issue it will not play, the timing gear is out of sync, or the laser pickup is not functioning, you will need to take it to a service shop for assessment.
Jun 02, 2012 | Philco (R) Classic Turntable CD Shelf...
Can't get the record player to work on a detrola
Thank you for the solution of moving the arm to the right and wait for the click, now my turntable works and Keely Smith is playing and sounding great!
Apr 22, 2012 | Crosley Audio Players & Recorders
I have a Philco turntable that appears to be in mint condition. I took it apart very carefully and there are no ribbons or anything restrsining it from starting. The belt looks great and everything is...
In some cases, when drive motors stand for a period of time, they tend to freeze up. The magnets can also loose their properties and the stator and rotor fail to operate normally. You may be able to break the rotor loose by splining the belt end with your fingers. Twist the spindle back and forth as it will not hurt the motors function. Also check to see if the electrical contacts are positive. If one wire is loose or the insulation cracked off, it could be shorting out. Using a Volt/Amp meter is necessary for a continuity test.
Feb 03, 2018 | Philco (841210) Turntable
Philco 841205 Turntable Logo
586 people viewed this question
Top Philco Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
