Question about Whirlpool Duet GHW9150P Front Load Washer
Vibrating Front Load Washer
I have a Whirlpool Duet the is vibrating the hole upper level of our house. Is this a problem that can be corrected?
  • 530 Answers
Probably not. did you just move in? have you always had it upstairs? the only way to make it so your house does not shake is to reinforce the floor.
Posted on Jun 01, 2010
Drum on duet washer is not finishing load, getting stuck, wont turn
Hello
you need to clean the filer on the front of the machine , or check the pump for a faulty impeller , a good. Clean of all the draining system would be a great start,
Oct 08, 2014 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET SPORT FRT LODER WASHER VIBRATES VERY BAD
Might be a simple fix. First, make sure your machine is sitting level (or pretty close to level) on the floor. Next, using a Torx bit (probably, that's what my 9250 had), unscrew the screws holding on the front access panel. When you look inside, you'll notice several shocks (usually 4) that stabilize the drum as it turns and spins. Make sure they are all intact and mounted to the drum (they have a tendancy, especially after having been run in an excessively vibrating state, to dismount from the drum). If the mounting pin is intact, stretch the shock to reinsert it into the slot on the bracket mounted to the drum, and turn to lock it into place. If the mounting pin is broken, you'll need to order another (probably the entire shock, actually) to repair it. Also, be sure that you are not overstuffing your washer, as overloading will also cause excessive vibration. Hope this helps!
Dec 07, 2012 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
Vibrating out of control ,i have level it and double check. whats the problem?
check the bottom for shipping screws, when the delivery men installed ours they never took them off-- this led to all the banging and shaking...( they were in the back on the bottom)
Dec 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine vibrating when spinning
you need to level the machine and then run the jamb nuts located between the feet and base of the machine tight against the bottom of the unit or they will turn and un-level the machine when you use it
Apr 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to keep the floor from vibrating while in spin cycle
Most likely cause of vibration is that the washer isn't leveled. Use a torpedo or carpenters level and adjust the support feet on the washer to get it level. If it still makes the floor vibrate, you may have a soft floor. You could then try putting a piece of 3/4 plywood under the washer to help support the weight.
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washe always out of balance
remove lower front panel and you should see shocks on lh/rh of tub. probably one broken ,replace both. Hope this helps, please rate my solution :)
Jun 25, 2009 | Whirlpool GHW9150 Duet Washer
Vibrating Whirlpool ghw9100lw2
At Lowes you can purchase foam rubber pads 4"X5" pack of two for $3.50. If walking forward and after cecking level and washer pads are tight, place half of one pad under each of the two front feet. Place the sticky side against washer feet. Solved my problem.
Feb 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Vibrating
if the machine is over a year old chances are that the tub shocks are going bad replace all four at the same time these are hard to figure which one is the one
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loading Washer Model GHW 9200 LW
what shoul I need to fix when the light sensing on and the dryer does not start ( it still hot ) .
Whirlpool dryer GEW9200LW
reply to tomagic3@yahoo.com
thanks
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Noise on spin mode fast loud clanking like something in drum
Wow, we're having a similar problem vibrating like crazy...just online to try and figure it out..
Dec 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
153 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
