Question about RCA M4204 MP3 Player
When turned on, stays in initializing
Doesn't work...
  • 820 Answers
Try a RESET, holding the MENU/On-Off button for more than 10 seconds.
When the player needs a long time to read a lot of files from one folder, reorganize files into a number of folders.
Should the player freeze, because the format of files does not match the M4204, use the easyRip software to get the data fitting for this device.
Need more help ? Then write your comment in this thread.
Posted on Jun 01, 2010
  • YourZEN
    YourZEN Jul 13, 2010
    Hello Kelly_beasle,
    Your solution seems to be a help request.
    It looks like the required or manually started upgrade, has not completed.
    When you run the firmware upgrade 2 boxes should open at the same time:
    1. Upgrade Instructions
    2. Audiovox OPAL Firmware Download
    When the firmware version details of box 2 have disappeared, look in the bar below to find and click it, to see if the current firmware inside the player shows up above the upgrade version. Version for the M4204, actual upgrade is 001.007.002 . Start the upgrade and wait until the task is complete. Finish the upgrade instructions.
    When the player keeps initializing do NOT close the 2 upgrade boxes and follow the trouble shooting steps:
    Step 1: Without closing the Update Device Application, disconnect your Player from your computer.
    Step 2: Reset your Player ( to be able to restart Initializing again, later )
    a. If your Player uses AA or AAA batteries, remove them from the Player
    b. If your Player uses an internal battery, press and hold the POWER button for 10 seconds
    Step 3: Hold down the PLAY key on your Player and connect it to the PC via a USB cable.
    Step 4: Release the PLAY key when a progress bar and text, "initializing" appears on the Players display. If you cannot see the "initializing" text, please disconnect your Player and try again.
    Step 5: Click the START button in the Audiovox OPAL Firmware Download as described in the steps of the Upgrade Instructions.
    Support overview for the M4204 on next internet page:
    http://www.rcaaudiovideo.com/mp3players/...
I have the same problem. I have downloaded the firmware upgraded from the rca website, formatted the player. I have also tried to reset it as stated. Nothing. However i can access it from the computer and play the music files before i formatted it. I have looked for a number for RCA customer support but havn't been able to find one. My computer will find it fine, but when i disconnect it from the computer and turn it on, it stays on the initializing screen. When i downloaded the firmware upgrade all it gave me was a box explaining how to do the upgrade and that was it..
Posted on Jul 12, 2010
Fryer turns on heats up and then will not keep temp.
You would be correct in your assessment to check the thermostat.
Jul 29, 2013 | American Range AF45LP Deep Fryer
Compaq c61 wireless button
are you saying it doesn't work when you press the hotkey to turn it on? is this just initially and then it works?
Jul 22, 2012 | Compaq Computers & Internet
The screen olways turn white
Initially you have to flash your mobile. update its firmware and then try.
If firmware up gradation doesn't work then this can be the issue with LCD itself.
best of luck!
Mar 10, 2012 | Motorola Mobility L71 Cellular Phone
When i turn it on, it stays black, cannot see anything, and yes i took the lens cover off.
hi let me ask you little more beside your description. would you check if you can see menu on lcd. if yes, then might has two cause. first is shutter doesn't open at initial power on position due to sand damaged or oil contaminate on blade. second is ccd unit or main pcb defective( more open to main pcb defective.) you could bring to your local repair shop. they will charge you around $85 to 135 if it is the problem... Good luck with you!
May 22, 2011 | Canon PowerShot SX100 IS Digital Camera
Stays on the Initializing screen.
remove all the files and then try
Aug 03, 2009 | RCA M4204 MP3 Player
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
Problem to turn on Philips TV
sound very much like the C.R.T is low emission the tv monitors the tube before showing a picture.either get the tube boosted or changed most tv shops should do i
Oct 18, 2007 | Philips 27PT563S 27" TV
RCA M4204  MP3 Player Logo
358 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
