Question about Dryers
Maytag Neptune Dryer Model MCE800AYW
THis a new Dryer in service for only a few months. However it was purchased two to three years ago so it is out of warrinty. When the Dryer is running there is a tumping sound. My big problem is how to get acess to the drum?
Dryer is throwing sparks when running and the back inside of the drum assembly is really hot to the touch?
Posted on Jul 11, 2011
Lower part Neptune dryer wont turn on
I could be all wet with this but have you check the switch on the door see if it's stuck----also the answers given before are good replies----do you have a schematic?----you've replaced the mother board so depending that's not faulty it should work or you've eliminate one issue---what ever sequence follows the events that start the dryer----by more info--- is the drum turning??----is it turning and your getting no heat----another issue which may or may not be the case is polarity via house wiring----have you had any recent issues with your wiring----wire changing and or service entrance---utility pole replacement----storms---lightning---these are things that can drive electronics nuts with out knowing it---this is all I can think of at the moment---get back to me with more info if you can
Feb 21, 2015 | Maytag Neptune MDE5500AY Electric Dryer
Brand new Maytag dryer has been coverted to propane and it keeps breaking (not heating up). The service contractor replaced some parts, tested it and worked fine for 1 day. Today I washed a blanket and...
even though the you might have a new dryer the vent line could be blocked with lint,or there are other parts that could go on a gas dryer,bad thermal fuse,gas coils,ignitor,sensor one of the thermostats,the only way to tell is to get in there with a meter,unplug the dryer remove at least one of the wires on the part you're checking and check the parts for continuity.that's a neptune those are the machines that put maytag out of bussiness a few years ago,i don't think it's new.you can go here and look up the parts i told you to check,if you need anymore help let me know.
Aug 24, 2013 | Maytag Neptune MDG5500AW Gas Dryer
Magtag Neptune Dryer - when I press start it say Pause and stops instantaneously. Anyone have this problem and know the solution?
sounds like a bad control board it seems like you have a letter missing in your model number ...I looked up the part ouch ..http://www.repairclinic.com/vwo1/Maytag-Dryer-Model-MDE5500AYW-ID-563862-Circuit-Board-Timer-Parts?s=t-mde550ay-%3d%3dd563862b4a8c13
Aug 14, 2013 | Maytag Neptune MDE5500AY Electric Dryer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Age of dryer
the production date is on a tag on the back of the dryer, this model has been around about 12 years
Apr 07, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The clothes are soaking wet after the run on the machine. It seems the spin function is not working. I have a maytag neptune model front load.
I have the same problem. I have spent about $1,400 in repairs on this damn machine since we bought it about 8 years ago. It works for a bit then something else goes wrong. This is the fourth time I've had this problem.
It's the belt, it's the motherboard, its this its that $200 a pop. Just enough to say ok, any more I'd buy a new one, then a few months later something else happens.
What happened to Maytag? My mom and grandmother both had maytags for years, decades without an issue. The new ones ****.
Nov 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune - everything works, not getting hot
check to see if it has an igniter if so that could be your problem.
Nov 22, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer door will not open
only the washer has a main bearing. the dryer only has bearings in the motor and still would not cost 1,000 to fix. did you door issue get fixed? Joe
Nov 13, 2008 | Maytag Neptune MDE5500AY Electric Dryer
How to convert from LP back to Natural Gas?
I have an old Kenmore dryer that I need to convert from LP to gas. I have the parts but no instructions. Can you please help?
Thank you, Roxanne
Mar 06, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Maytag neptune dryer won't start
Just a quick question before I look at the control board myself. What are the values/ratings for the capacitor and resistor (ex. farads for cap, ohms for resistor, and volts/amps for both)? Or give me the Vender Part Number so I can look this information up. Thanks!
Jan 27, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
276 people viewed this question
Top Dryers Experts
