Question about Kenmore 43142 Front Load Washer
I have a kenmore 43142 front load washer. it suddenly made very loud noise when spins. found 2 break pieces off the back cover of the tub, near counterweight, drum rear (part No 134125900). it sounds like some loose pience stucked inside, but it's so deep to take it out. any suggestions will be appreciated. thanks. wayne
    President:
  • 1,554 Answers
Most likely a screw or other debris has stick out of the inner drum and damaged the outer tub. Inspect the inner drum for any screw head and remove it. On other cases, bra under wires can get through the holes of the inner drum and get stuck between the inner drum and the outer tub.
Disconnect power to the washer then remove the three screws securing the top panel to the rear of the washer. Slide the panel rearward and lift it off the washer then disconnect the ribbon connector from the left side of the central control unit.
Pull the dispenser drawer out then press down the release tab to completely pull it out of the washer. Once the drawer is removed, remove the screw in the recessed hole next to the drawer opening then release the tab securing the right side of the console to the cabinet.
Open the washer door and insert a flat-bladed screwdriver into the slot in the bottom center of the console. Pull the console up to release the console center tab making sure the ribbon cable clears the cabinet frame then remove the console from the cabinet.
Prop up the bottom front edge of the washer or cushion the rear top edge with cloth and lean the washer against the wall for easy access to the three screws securing the lower front access panel to the cabinet. Remove the screws then pull down the lower front access panel to remove it from the cabinet.
Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the door gasket off the lip of the right side of the door opening then place it inside the basket.
Disconnect the wiring harness from the door lock and switch assembly then remove the screws attaching the front panel to the cabinet and remove the panel. Remove the clamp securing the door gasket to the lip of the outer tub then using a picking tool, remove the trapped debris.
Posted on Jun 01, 2010
  • Jahn27
    Jahn27 Jun 01, 2010
    Follow the disassembly steps in reverse order when putting up the washer parts together again.
My 7 year old he3 has a terible thumping noise when in the very fast spin cycle it is like the tub is coming out. The spin cycle before last is not as bad. the shock absorber are ok I can take the front of...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 11, 2011 | Kenmore HE2 Plus Front Load Washer
When on the spin cycle it makes a very loud noise, what is this
Washer Problems
heatman101
Feb 02, 2011 | Kenmore 44102 Front Load Washer
Loud shaking in the spin cycle
Washer Problems
heatman101
Jan 19, 2011 | Kenmore HE2 Plus Front Load Washer
Washer making alot of banging noise, I this the part that spins the clothes is off its brackets or somthing. The spinner is very loose.
Washer Problems Washer noise when spinning
heatman101
Nov 16, 2010 | Kenmore 43142 Front Load Washer
Washer makes loud noise during spin cycle
heatman101
Aug 31, 2010 | Kenmore 4292x Front Load Washer
Inner drum seems to have broken away from outer drum
please contact applianceparts.com on the web I believe they will be able to find a similar part such as a whirlpool tub support then: all you will need to do is drill new holes and, bolt it in both the tub and the support the whirlpool part includes both the assemblys
Apr 11, 2009 | Kenmore 43142 Front Load Washer
Kenmore HE2 Front Load Washer
is it level ? i had to level mine then i had a nut that come off had to put that back on on i am all set
May 22, 2008 | Kenmore 43142 Front Load Washer
Slow to spin and making a loud noise.
Control boards don't growl, the fry out and die. Sounds like a drive train problem to me. If it's a front load machine, the spindle/bearing assy. has gone to washer heaven. If it's a top load machine... could be the transmission, brake/clutch assy. or the tub bearings. In either case, if it's less than 5 years old, the drive system will be warrantied through the manufacturer. If you could provide a make and model number, I could narrow this down to a fine point.
Dec 15, 2006 | Kenmore 43142 Front Load Washer
Kenmore 43142 Front Load Washer Logo
80 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
