Question about AT&T High Speed DSL Modem
Modem resets its self and can't connect to server,repeated calls
  • George Bill
    George Bill Jun 01, 2010
    You need to be more specific, are you saving the settings when you close the setup page?
  • 70 Answers
Unplug everything and then plug it again. if still dont work then, check the reset button may be its pressed down. still not working then you need to get it repaired or change it if its under warranty then good.
Posted on Jun 01, 2010
Batch out omni 3730
in order to settle or batch you will press the purple "more" key or the purple key to the far left until you see settle or close, then confirm amount. if you get a error message you will need to call your processor. if you get a QD followed by numbers or RB followed by numbers you need to call processor. if you take tips and have not adjusted them it will prevent from settling at times, check your sales by printing a report, press the purple key to the right of the alpha key above the 2. check your reports and try again. if you are getting can not connect to server or host, then you do not have a good phone or Ethernet connection. check those and reset the modem or terminal by unplugging and plugging back in right away. may need to leave unplugged for 60 seconds if it does not reboot it self.
if you lost the sales call processor.
Jul 29, 2014 | VeriFone Omni 3730 Aka Vx510 Credit Card...
RCA DCM425 modem ethernet connection won't work
The setting for the Computer 1, use the network connection wizard to automatically configure the modem to work as a server station. Next, set the IP number manually and the DNS at automatic or is given by your ISP. Now the Computer 2 (workstation) should be connected to a Hub/Switch. The same, go to network connection wizard and select the appropriate connection setting, there are view samples for the connection types so explore them. After the setup, try loading your internet browser.... When done, it should work fine. Keep me posted for any problems.
Nov 26, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Connecting to matchmaker server is not working
Try resetting your modem and PS3's internet connections..
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and go through the motions again.
Good luck.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
Diffrent between Dynamic&static ip address
Static IP address is usually a single IP address provided by the ISP to you, which can be configured so that you can run a web server (host web sites etc), or access your home computer from any where in the world ( your computer and internet should be on ).
Dynamic IP address is usually IP address provided by the ISP to your DSL modem / computer (for dialup modems) for that internet session, next day or next time you connect the IP address will be a different one. (usually home internet connections are Dynamic IP based.
In a typical home environment if you have one wireless adaptor and planning for a wireless repeater its better to configure dynamic IP address in the repeater (so that you repeater will acquire IP address from the wireless adaptor)
Dec 09, 2010 | Computers & Internet
Lights flossing from right to left on sequence repeatedly and then automatically resetting
Hi there
With this kind of problem, its showing that the modem is not acting well. You don't want to keep on getting disconnected from you internet. Just call your internet provider and have them replace the modem because modems just don't reset by itself. Be aggressive when asking them to replace the modem . ^_^
Sep 16, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
Help, my voice call in Yahoo messenger suddenly will not connect to the server. I have been making calls from PC to PC for many months and lastnight it just stopped letting me connect to my friend. I get a...
As you said you were able to call or using the voice call from yahoo messenger for 2 months I understand that your IP( Internet Protocol) address is banned from yahoo voice server.
To fix this issue, If you are connected through a personal modem restart your modem in order to change the IP.
Or if you using Fix (static)IP address from your ISP/Network vendor ...contact them to change the IP or try use VPN(Virtual Private Network) connection to authenticate/connect with different address.
Hope that will help you.
Thanks for joining us.
Good luck
Nov 21, 2009 | Yahoo Messenger
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
Help
That means it hasnt picked up an IP from the modem.
Unplug the power to the modem and the router. Leave them off for a full minute. Pluge the modem in first , give it another full minute then power up the router. If you still have problems try another cable.
If you still have issues, Power off the modem and the PC and repeat the above process.Verify the PC is getting connection. If you cant connect then call the cable/DSL company.
If you can connect download the latest firmware from Netgear and flash the router.
http://kb.netgear.com/app/products/model/a_id/2589
Mar 04, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Modem Problem?
In order to really test your modem you need to call more than just 1 (your ISP's) number. If you are not getting 56k connects, you should try your modem with other local/toll/toll-free numbers. This is a list of some toll-free numbers, the 3Com "Line Test" Number (a toll-call), and links to various ISP local access number listings Setting up an account with a Free ISP is another way you can test and isolate modem/ISP problems.
1-847-330-2780 - USR Linetest number - this is a toll call; if you log-in as "Line Test" with a v.34 modem, it will attempt to determine if your line will support 56k connections.
1-847-330-4569 - US Robotics' V.92 Test number - this is a toll call; the server is a 3Com Total Control HiPer ARC running V.92 server side code that supports PCM upstream.
The following numbers use toll circuits but are free to the caller (as long as you don't log in):
1-800-245-3828 - (Canadian weather BBS)
1-800-590-4857 - (IBM Global network access # x2 and V.90 3Com Server)
1-800-784-3638 - (Netcom - supports V.90)
1-888-861-8490 - (MCI/Worldcom))
1-888-245-0113 - (AOL access x2)
1-800-716-0023 - (AOL alternate access)
1-888-296-3892 - (AT&T Worldnet accessV.90,x2)
1-800-638-1483 - (GTE Net access - V.90/K56Flex Ascend Server)
1-800-572-1959 - (Compuserve V.90,x2)
1-800-350-6885 - (Earthlink - V.90,x2)
1-800-853-7921 - (Earthlink - Flex)
1-800-534-7097 - (Earthlink - Flex)
1-800-304-4226 - (Shore.net - Flex)
1-800-320-4509 - (Ascend 56KFlex test line)
1-800-779-2966 - (Used to be MCI)
1-800-846-7562 - (Gateway BBS)
Apr 03, 2008 | Agere (DSLU56KPCI) Modem
AT&T High Speed DSL Modem Logo
265 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
