The current power supply is constant, { coming straight from the battery supply}, you need to disconnect that wire and connect a wire coming from the ignition, using a circuit tester, locate a heavy wire that only lights the tester when the ignition is on. I would still recommend using a fusable link before bare connection. This will solve your problem, Cheers.
my problem related to ASD (automatic shutdown relay) wiring not tight on terminals (fuse box under hood). I traced this to a mechanic (national chain) repeatedly kept dislodging the ASD wiring (while supposedly tracking down fuel pump problem). This act eventually caused the computer to fry.
Sounds like its a bad blower motor connector,Find blower motor connector and perform a wiggle test while turning fan switch up and down.Also look at connector for melted wires or the connector itself.Hope this helps!!
itsounds like they are shorting out . you will need to follow the wiring for your signals and look for a wire that is shorting out, and be sure to check the ground wires as well.
