Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
GE profile Artica side by side does not get cold enough !
GE profile Artica Counter depth side by side refrig only gets 22F on Freezer, 45F on refrig.
Compressor is running & hot. I noticed the front center wall that divides freeze/rifrigerator (where the doors close on ) is very hot. Any idea would be greatly appreciated.
TheMobilian
  • 8220 Answers
SOURCE: GE Profile Artica refrig is freezing food
Replace the cold control
Posted on Apr 09, 2009
  • 235 Answers
SOURCE: GE profile counter depth side by side stopped
Is the compressor coming on at all? If not a capacitor may be bad .
Posted on Jul 05, 2009
  • 10865 Answers
SOURCE: ge profile artica not cooling
  • Is the thermostat knob turned to the proper setting? If not, reset it.
  • Next, see if the compressor motor is running
    The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
    • The compressor
    • The Thermostat
    • The overload, relay, or capacitor
    • The defrost timer
    • The condenser fan motor
    Posted on Aug 16, 2009
    heatman101
    • 43501 Answers
    SOURCE: The freezer is not cooling and refrigerator is not remaining cool
    Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
    If your refrigerator is running but warm, then...
    Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
    Refrigerator Condenser Coil Cleaning Refrigerator Repair
    Refrigerator Troubleshooting Refrigerator Compressor
    Refrigerator Compressor Start Capacitor and Start Relay
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    sfgmjfmkxf
    Posted on Sep 29, 2010
    tunde007
    • 2382 Answers
    SOURCE: GE PROFILE ARTICA REFRIG. MADE
    Hi, that's usually the mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
    Posted on Nov 08, 2010
    My GE Profile Artica PSI23SCN refrig. temp on the refrig side stays at 27 degrees. I turned up the freezer temp to 6 and the refrig went up to 31. I called arepair guy and he said he had a client with the...
    Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
    Refrigeratoris Too Cold and Freezing Food
    heatman101
    Apr 02, 2011 | GE PSI23SCN Side by Side Refrigerator
    GE Profile Artica icemaker does not make ice. model # PSC235GNA. We still get cold water .
    use a thermometer make sure freezer is normal operating temp if freezer is cold enough and water is filling ice maker you may have bad ice maker very simple system make sure your getting water 1st thing to check is for water if you have water and freezer is cold youll have ice
    Aug 18, 2009 | GE Refrigerators
    GE Profile Artica side by side - freezer not cold enough
    replace control board on back of unit there is a six by 10 inch cover on back your panel is in there cost aprox 169.00 dollers also replace bo0th thermisters bottem left of freezer looks like a white bullet the other is in fridge behind shelf trim located beside and underneath where the cold air blows into the fridge.
    Aug 10, 2009 | GE Profile PSI23NCR Side by Side...
    Jul 05, 2009 | GE GSH22JFR Side by Side Refrigerator
    heatman101
    sfgmjfmkxf
    Jun 25, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
    GE Profile Artica side by side stainless steel wont get cold
    The Profile and Artica are good refrigerators. the problem may be the defrost element, defrost thermostat or the mother board. Let me know if you want help on this one. Thanks Sea Breeze
    Jun 18, 2009 | GE Profile Arctica Stainless Steel Top...
    GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
    Use the damper control to direct less air into the refrig compartment from freezer
    Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
    GE PFS22SISBSS Refrig compatment freezing
    There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
    Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
    Ge profile artica side by side refrig
    is it the type of doors with the plastic snap on caps that cover the hinges, if so pop them off and unscrew, if it has an ice maker on the door its more complex, good luck
    Mar 13, 2008 | GE Profile PFS22 33" Artica French Door...
    Refrigerators Logo
    162 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    dweatherby
