Question about Konica Minolta magicolor 2430 DL Laser Printer
Fatal Error Code 1BH - Konica Minolta magicolor 2430 DL Laser Printer
2 Suggested Answers
SOURCE: Konica magiclolor 2530 DL Fatal Error 1bh
I have the same problem and I can see that the black "V"shaped piece is loose and sometimes keeps the cover from opening.
I can not see where to put the screw to fix the problem. Any suggestions?
Posted on Sep 21, 2009
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
Fatal error 0000000000
Is the operating system Microsoft? When does the fatal error occur, when the laptop starts up? Are there any other letters at the end of the error code, please reply with the full code.
This link has examples of possible error codes:
http://support.microsoft.com/kb/150314
Jan 11, 2013 | Acer TravelMate 4100 Notebook
Fatal error code 2124 on Rosetta stone
There is file called tracking.db3 which gives us lot of error like 2124, 5611, 2123 etc.... you can find a perfect fix at Questions Rosetta Stone Community
Jan 03, 2012 | Rosetta Stone 1, 2, 3, 4 & 5 Set English...
Error 030 fatal error
ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply means a problem has occurred requiring you to take action. It does NOT mean that your printer has "died". ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
May 25, 2011 | OKI C5200n Laser Printer
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
Basically the fuser is not operating properly. This fault can be caused by 1 of 4 things. The fuser itself, the engine control board, DC power supply unit or the fuser safety switch lever hinge. The easiest to check first is the hinge. Disconnect the power cord and remove the Left side cover. Beneath this is a boomerang shaped lever arm with a pivot in the middle. As this pivot is plastic it can break over time. if you can source an appropriate self tapping screw, this can effect a repair.
Nov 03, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Fatal Error 21H
FATAL ERROR CODE 21H / SERVICE CALL 21 TRANS DET SENS: Malfunction of the OHP detecting sensor
check the OHP detecting sensor (PC3A) (it's at the front above the waste toner sensor pc6)
May 22, 2008 | Konica Minolta magicolor 2300DL Laser...
Fatal Error 162
I am pretty sure this is the result for your 162 code:
Toner Sensor Error, Color:Cyan
When cyan toner sensor error has occurred
Try reseating your toner carts.
May 14, 2008 | OKI C5150n Led Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
208 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
