I have a brand new Maytag 3000 washer and it keeps flashing a code that says F 20. What does this mean? This is my first time using this washing machine.
  • 530 Answers
Check to see first if you have water comeing out of both hot and cold hoses. are they turned on? take the hoses off the washer and get a bucket and turn one hose on at a time 1st the hot then the cold what happens?
Posted on Jun 01, 2010
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
F11code on a maytag
The F11 code on a Maytag means there is an electrical issue somewhere in the washer. I would leave it to an expert to diagnose since it could be one of several things.
Nov 26, 2014 | Maytag Washing Machines
A code saying 5d or Sd is coming up on my machine, what is that
The code Sd means that suds were detected. Generally this means you used regular detergent instead of the HE detergent. Less often it indicates that you used more detergent than needed for the load.
Remember to use an HE (high efficiency) detergent and to follow the directions for the amount to use in a wash cycle.
The washer should do a suds correction program to make sure that the clothes are fully rinsed. However, if the code remains and the wash cycle dial is flashing, set your washer to repeat the cycle with cold water without adding additional detergent. (Every portion of the wash cycle will be extra rinses.)
The manual for the washer is available as a PDF from Maytag's support site. http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10092824.pdf is the manual for the MVWB750WB0. Additional manuals for MVWB750W washers are listed here: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MVWB750W&siteCd=MT_EN_US .
I hope this helps.
Jun 02, 2011 | Maytag MVWB750W Top Load Washer
My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
MAYTAG 3000 SERIES JUST RECEIVED AN F20 CODE. WHAT DOES F20 MEAN? THE MECHINE RAN FOR 10 WASHING THE STARTED STOPPING ABOUT 10 MIN IN TO THE CYCLE WITH F-20 FLASHING.
need the correct model # and ser # _ _ _ 3000 _ _ _ _ this tell us age and and fault codes . now inside the machine / you will find a tec sheet with the codes . this may be quicker .. mm
Dec 02, 2009 | Dishwashers
Error code OE does not finish whole cycle
Just resolved same problem...it is the pressure switch aka water level sensor.  OE is overflow error.  Pressure switch is located under top cover on front right hand side.  It is round and has a rubber tube leading down to the drum and a electrical connection to the board.  Paid maytag man to diagnose/install cost me about $150
Oct 11, 2007 | Maytag Neptune MAH9700 Front Load Washer
Frigidaire affinity front loading washer
Any E20 code means your washer doesn't drain.  More than likely there is a screw, nail, coin, bobby pin, etc locking up your pump and causing it not to drain.  Keep in mind that your washer has a 1 yr warranty but some service companys will charge for this kind of repair because it is not technically covered under warranty.
Aug 21, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
