Question about Whirlpool LER5636P Electric Dryer
Dryer keeps tripping the breaker - Whirlpool LER5636P Electric Dryer
  • 156 Answers
Need more info does it run for awhile before breaker trips
Posted on Jun 03, 2010
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
aborcass
  • 2651 Answers
SOURCE: my whirlpool tumble dryer keeps
if it trips it off immediately after starting or wont even let you reset the breaker, you have a direct short(wire off a terminal ) or your heater element has broken and is hitting against side wall
Posted on Mar 24, 2008
thedayos
  • 57 Answers
SOURCE: My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
Posted on Feb 28, 2009
  • 686 Answers
SOURCE: How do I reset breakers on whirlpool duet dryer?
What size breaker is the dryer on it's should be at least a bouble 30 Amp breaker
Posted on Mar 06, 2009
josecolono
  • 6 Answers
SOURCE: dryer keeps tripping breaker
THE BREAKER IS GOING BAD REPLASE IT OR THE BREAKER IS TO WEEK FORE IT TRY ANATHER PLUG
Posted on May 15, 2009
Tcl 770 keeps triping power
Check to make sure the breaker is rated for the current draw of the dryer. If it is, you MAY have a bad breaker. Replace your breaker and If the dryer is still tripping the breaker, your dryer needs to be repaired by a qualified technician.... the heating element is probably burned up and shorting out.
Mar 02, 2014 | Hotpoint Dryers
Kemore elite dryer keeps knoting the breaker
Here is a tip that I wrote that will help you ti find out why the circuit breaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Oct 03, 2010 | Kenmore Dryers
I have a sears kenmore gas dryer model 87592820 it keeps blowing the breaker. It was running about 1 min. then a spark flew out and it tripped the breaker. When I reset the breaker it continues to trip it....
This sounds like you have a wire that rubbed through and is shorting out...
open up the back or where you saw the sparks come from and you will easily see the burnt mark...then you can fix it...
Do not keep trying the breaker... it is tripping to protect you and keep you safe.
heatman101
Sep 28, 2010 | Dryers
Dryer trips circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
heatman101
Nov 21, 2009 | Kenmore 63942 Dryer
Dryer keeps tripping the circuit breaker
hello mam please change the mains breaker after tripping for several times the breaker will be defected and check the power socket outlet by removing the socket there should not be any loose connections and skinned wires.
Oct 02, 2009 | GE Profile Harmony DPGT750EC Electric...
Tumble dryer keeps tripping the mains
The twin breakers for the dryer circuit should be rated at 30 amps. Have the current draw checked on each wire leading from both breakers (with a clamp-on ammeter) while the dryer is operating. If the breakers trip just as soon as the dryer is started, there is very likely a short to ground/neutral within the dryer case (usually the heating element).
Aug 04, 2009 | Dryers
Dryer keeps tripping breaker. slight burning
The heating element is shorted. This is an electric dryer, right? replace the heating element. Make damn sure it's un-plugged when you work on it!
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
May 14, 2009 | Dryers
Our kenmore 697267 keeps tripping it's circuit every 5 minutes or so... what's the problem with it? Is it dangerous to just keep resetting it?
definatly a prob if tripping breaker every5 miin, resetting breaker is not good for either the breaker nor hte dryer, that would be hard to determine why without actually looking at though, i would probably calll someone to have a look at that one
May 02, 2008 | Kenmore 73952 Gas Dryer
Whirlpool electric dryer keeps tripping main circuit breaker
Feb 02, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
149 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
