Question about LG Refrigerators
LFX 25950TT problem
Refrigerator has error code ER IF on front panel. I'm told by LG that this stands for "error ice fan". Unplugging refrig for 3 - 4 hrs per recomendation did not help. Sears technician took a bunch of panels apart today, concluded along with supervisor on phone after 2 hrs that Ice Fan indeed does not work. Now rescheduled to replace circuit board (this will be the second time!) and Ice Fan. Seems to me that if he had the right diagnostic tools that he could have come to that conclusion WITHOUT taking apart the refrigerator. Isn't there some kind of diagnostic tool that plugs into the control board to read faults?? Is this a common problem? Refrigerator was purchased in Oct 2007.
Just had this same problem. We were away at Disney for four days - turned the icemaker off before we left. We have the LG french door double drawer freezer model. Came home, the ER IF code was displayed. Wouldn't dispense water or ice. Took the icebox out, and it was all frozen in the augers. Then I read on the door something to this effect - "if you turn off the icemaker, it will not continue to cool the ice. This will cause the ice to melt and leak out of the unit, and when it refreezes, the dispenser will not produce ice or water."
So, I took the ice box out, emptied it, reinstalled it, and the unit os making ice and dispensing water as I write.
Again, if you turn off the icemake, empty the ice box, or you will get the error message when you start the ice maker again.
Posted on Dec 25, 2008
LG Ref/Frzr LFX 31925st ERROR CODE ER 1F NEED MEANING AND FIX
A F1 or 1F error code on the refrigerator's display indicates a problem with ice blower fan or ice maker motor.
search LG error 1f and u will find lots of info
Dec 09, 2016 | LG Refrigerators
What does message Er IF mean?
LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message.T his error code indicates a problem with the fan that controls the unit's ice production. If this problem occurs because of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to thaw may fix the issue. Call customer service if that doesn't work.
Oct 12, 2012 | LG Refrigerators
Refrigerator displaying error "ER FF".
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue.
This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
Hope this helps.
Jun 10, 2011 | LG LRFC25750 Refrigerator French Door
I have an ER 1F. I had this problem and took 6 months with LG to fix it. When they couldn't fix it they gave me my money back and said keep the frig. So I bought another and this sits in my garage. I...
1. yes. Open ice room door (back side of left hand refrig door) and turn toggle switch on icemaker to OFF. 2. yes. Do step 1 and connect water to refrig. 3. ER IF (Error Ice room Fan) may still come up. If it does and you don't like it, you could probably avoid that by removing the fan blade from the ice room fan, located in the freezer section, behind the back wall, upper left hand corner. The error code pops up when the electronic board does not see a feedback signal from the ice room fan. Removing the fan blade should allow the motor to run, thus sending the feedback signal to the board, preventing the code from appearing.
Mar 21, 2011 | LG LFX23961ST Stainless Steel Bottom...
We get no water or ice from control panel. On panel it says Er iF. What does that mean and how can we fix it. We have tried resetting the power and it goes back for a second then returns to Er iF.
Er IF - Ice-maker Fan Error - This can be caused by frost accumulation on or around the ice maker fan. Unplug the unit for 3-4hoursto allow this to melt off. If error code persists, call customer care to check & replace ice maker fan motor.Thanks.
Jan 29, 2011 | LG LFX21960 Stainless Steel Bottom Freezer...
The door panel says "Er FF" and now it is not cooling
Er FF - Freezer Fan Error - This can be caused by frost accumulation on or around the freezer fan. Unplug the unit for 3-4 hours to allow this to melt off. If error code persists, call Customer Service.
Oct 30, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
I have a Kenmore model 795 77563600 refrig side
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG refrigerator lrsc26944tt error code ER FF
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
Jan 25, 2009 | LG LRSC26944TT 36" 25.5 Cu. Ft....
Error message on LG Refrigerator
The message is ERROR ICE FAN. You can order a new one from LG for around $65 and if you know someone handy they can probably put it in by just eyeballing the old one. WARNING>>>>this must be someone with common sense and some degree of problem solving skills as it does not come with the fan blades and that must be switched. This is a common problem with this model and usually the ice fan goes out in about 12-20 months. Use your owners manual to figure out how to get the door off and access the fan. Also, Lg employees are confused and may try to tell you there is just one fan......they did tell me that!
The ER IF is part # 46811B1029E---The ER FF (freezer fan) is part # 4681JK1004E and only a skilled repairman can modify them to be interchanged.
Dec 07, 2008 | LG LFX25960 Bottom Freezer French Door...
LG Refrig LFX25960SB
The service manual with the codes is available at:
LG LFX25960 Service Manual
"ER IF" show a problem with the ice maker fan motor.
Nov 06, 2008 | LG LFX25960 Bottom Freezer French Door...
Refrigerators Logo
560 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
