Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
On a Kenmore frontload washer Model#11047087600-theF30 error code comes up, Sears checked & said it means a long fill. Screens are clean--good water pressure to washer.Washer filled okay for me-lady said F30 error code was back later. F30 on some models refers to dispenser motor not being able to find a position.Would either go back to a water entering problem? Rene - ed okay for me
  • Rene Matz Jun 08, 2010
    I replaced the ccu board on this washer--dispenser motor seemed to find its postion after I lubed the
    linkage arm pivot points. is there any parts that should be replaced or can dry joints stall out a motor?Nothing appears to be worn. Thanks. Rene
    President:
  • 1,554 Answers
The F30 code on your washer definitely means dispenser motor error as you have stated in your post. Verify it by entering the diagnostic mode.
Close the door and select any one button (except “Stop/Cancel” and Control Lock (End of Cycle) and follow the steps below, using the same button:
Press/hold for 2-5 seconds, release for 2-5 seconds, press/hold for 2-5 seconds, release for 2-5 seconds, press/hold for 2-5 seconds.
Upon release, all yellow/green console LED lights will turn ON for 5 seconds. The last 4 error codes will be displayed, if there are any failure codes stored by the washer. Press the same key to advance to the next code.
The UI ,CCU and MCU SW version will be displayed after the error codes are shown. All green console LED lights will turn ON for 5 seconds then the washer begins the automatic diagnostic test. Press STOP button to cancel and exit out of service mode.
Posted on Jun 08, 2010
  • Jahn27
    Jahn27 Jun 08, 2010
    Take a look at the washer while performing the diagnostic test to determine on what step of the test the F30 code appears. The dispenser motor is indeed cannot be driven to its proper position if the F30 code flashes during the C:02 step of the test as this is the step where distribution system is set to Prewash position to check the dispenser motor and the dispenser contacts.
  • Jahn27
    Jahn27 Jun 08, 2010
    Check the connection of the dispenser assembly to the CCU if the dispenser motor seems to find its position. No other part could make the dispenser motor stall except the levers and cam. Consider replacing the actuator switch (part number 8183186) if the connection to the CCU is found okay.
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
FF error code - fills up & won't drain
sorry but we have the same problem that the sears repairman had no model number gives us no choices . suggest you buy a new machine, but not Sears brand as they seem to be going out of business world wide
Oct 26, 2017 | Kenmore Washing Machines
Washer flashes f 1 on the display window
The F1 error means that water pressure into the washer is out of range...the control on the washer learns the water pressure coming in from when it was brand new it is capable of learning just the water pressure to your house since it will vary from your neighbors...after it has learned what the normal pressure is if it doesnt see that normal pressure coming into the washer it will throw up the F1 error code
What to check is if water is coming into the washer from the rubber fill hoses with as much pressure as always did...things that could cause lesser pressure is; kinked/crushed fill hose,sediment built up in the filter screens inside of the water inlet valve( can be checked by turning off water and removing hoses and pop screen out from the back of washer where the hoses connect to)
If the filter screens are clear and water seems to coming from the hoses with good pressure...the washer control board would need to be replaced
GENE
Sep 06, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite oasis model 110.27032600 LF error. had an issue with the washer cycling through all the lights, would turn it self on etc. Had the repair man come out and he replaced the computer board....
The LF error means Long Fill.
When you start a cycle the water should come into the dispensers. If you have a good flow through the dispenser the valves will be okay.
I recommend checking the inlet water screens on the back of the washer. The inlet screens are located on the water valve. To access the screens you will turn the water off and remove the inlet hoses. The screens prevent debris from entering the valve and sometimes over time mineral deposits build up on the screens. This can block the water or slow the water fills down to a trickle. You can pull the screens out and clean them if necessary. Flush the inlets thoroughly with water when replacing the screens. If debris gets past the screens, it can cause the valves to stick open and an overflow of water can result.
While you have the fill hoses disconnected, place the ends of the hoses in a bucket and briefly turn on the faucets to check for proper water pressure and flow from both hoses.
A common reason for an L F (long fill) error on this washer is the drain hose being stuck to far down the drain standpipe.
If the drain hose is to far down the standpipe then a siphon can occur which causes the washer to fill and drain at the same time. This will cause a long fill error.
Feb 02, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore frontload washer, model#11047087600-- F71 error code displayed--what does it mean? thanks Rene
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 06, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite model #110 27082601
In reference to the LF error code on your Kenmore Washer
When your washer displays error LF , it is due to low water pressure, slow or continuous fill.All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems;
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine isn't supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house
* Error Codes- LF for long fill or FH for no water detected.
o A plumber may need to be consulted if the pressure is found to be too low.
Apr 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
338 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
