Question about Sport & Outdoor - Others
My three wheeler wont stay running.I HAVE TO PULL THE STRING OR PUT BOOSTER CABLES TO IT TO CRANK IT THEN ONCE ITS CRANK IT STAYS ON FOR AT LESS A FEW MINS.THEN IT CUTS OFF,AND IT WONT START TILL I REPEAT MY STEPS AGAIN PLEASE HELP ME FIX MY 1985 125M 3 WHEELER
  • Sport & Outd... Master
  • 12,061 Answers
Http://pdftown.com/Honda-NSR125-Service-Manual.html
I suspect your alternator and/or battery have gone faulty, the battery because the alternator, isn't charging, and the alternator because it is not suppling charging current. Either that of the battery charging circuit, has faulted. You should troubleshoot this and see if you have good output from the Alternator, and changeover, and battery charging circuit.
www.repairfaq.org/samnew/lmfaq.htm
www.diygokarts.com/.../small-engine-troubleshooting.html
www4.briggsandstratton.com/miscpdfs/.../alternator_replacement.pdf
http://www.buzzle.com/articles/alternator-troubleshooting.html
Please use these links above to help you, above is a altenator troubleshooting, above that, how to replace an altenator, above that is small engine troubleshooting and above that, is a repair site to help.
Posted on Jun 01, 2010
  • Demetrius Brown
    Demetrius Brown Jun 02, 2010
    THIS ISNT A CAR/BIKE WERE TALKING ABOUT THIS IS A 1985 125M 3WHEELER THAT IM HAVE THE PROBLEM WITH.
  • Demetrius Brown
    hey silver dragon are u there, is this about my 125m1985 3wheeler because this what im talking about
    HELLO,
Trying to find out if engine seized or just pull string messed up.
more than likely yes because an auto matic wont be direct drive
May 28, 2016 | Garden
My grandson pulled string and magnet off and now it wont work
It's a safety mechanism. You are supposed to clip one end to you (the person on the treadmill) and the other stays on the treadmill. If you fall or have an emergency, it should pull off, stopping the machine. To get it to work again, just put the magnet back on. If that doesn't do it, restart the machine with the magnet in place.
Jan 28, 2016 | Proform Exercise & Fitness
Wheeler wont stay running even after it's warmed up. Choking it won't keep it running either. This just started the other day. No issues up to this point.
Remove the play in the throttle by loosening the locking pin on the cable, then pull the cable tight to remove the play and refix the locking nut. Once the play is removed adjust the jet so that its steady at idle.
Dec 04, 2015 | ATVs
My three wheeler doesn't stay running when it starts. What could be the problem besides the fuel line . just added a fuel filter on it but she still won't start or stay running at times. Co
The damage is already done before you put the fuel filter in. (dirt in Carb)
Remove your carb and dissesemble it and clean everything out and then put back on the machine with FRESH gas and you will be fine...run like a top !
Jul 06, 2012 | Cars & Trucks
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
When i crank my four wheeler it wont stay running unless i pump the throttle its a kawasaki bayou 220
Try installing a new carb kit and that should help.Thanks for asking and I hope it helps
Jul 21, 2010 | 1996 kawasaki ZX-6R Ninja
It will turn over but not crank. it did crank once and as long as I didn't give itigas it would run. I had just put gas in the tank from Shell. Why will it not crank?
there is a micro switch in the throttle housing that will kill the spark if the cable is crimped or broke anywere. if you pull the cap and press the throttle and release it and you hear a click you just have to adjust it so the switch stays pressed when the throttle is all the way out to idle possition
Jan 22, 2010 | Polaris ATV
95 nissan pickup wont start
if u cant find any info about the diode try a used alternator should b cheap fix
Mar 03, 2009 | 1997 Nissan Pickup
1988 Yamaha 4 wheeler slow crank
put jumper cables from battery to starter directly
to see if it turns over faster put red on starter lead and black on gorund(metal housing)
You may want to try this from a car battery to see if it spins faster if it does it indicates a problem with power from new battery check cables and lines for power blead
Jan 04, 2009 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
24 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
