Question about RCA HD52W59 HDTV Projection Television
My TV turned itself off, and now when you try to turn it on the light on the power button lights up, it sounds like it is starting to power up but after about 5 seconds the green light on the power button goes off and of course the TV does not come on.
  • RCA Master
  • 8,617 Answers
That model is famous for the deflection board having issues. You can get a new Deflection board for your model is available from www.tvrepairworld.com
Posted on Jun 01, 2010
4 Suggested Answers
SOURCE: tv sound and pic goes out and green light flashes for 38 seconds
I have the same tv and it did the same thing. I replaced my lamp and it corrected the problem.
Posted on Mar 07, 2009
ladywinn
  • 5138 Answers
SOURCE: Turn power button on green
CK the Deflection board, Will be Located on Bottom far left hand side,has FBT flyback Transfomer. Look for Bad Capacitors
CP150 2200uf 16v use 25v CP114 CP120 If any of these are Swollen,vented or puffed up on Top they are Bad . Radio Shack should have these Caps.
Posted on Oct 11, 2010
  • 608 Answers
SOURCE: TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
Samsung la32s81b
Probably the power supply is failing or has failed.
Oct 24, 2017 | Televison & Video
Sanyo dp50747
sounds like a mainboard problem
Jan 31, 2013 | Sanyo DP50747 50 in. Plasma TV
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
My JVC 27" can not be turned on or off with the remote or the on an off button. Any ideas?
try all in one remote/it can be the infrared on tv not picking up signal/point remote does light flash on tv ?
Dec 23, 2009 | JVC AV-27530 27" TV
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
108 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
