Question about iRobot Roomba 560 Robotic Vacuum
IRobot Roomba 560 Thumping, Says Clean Brushes, No Dirt in Cup
I have a iRobot Roomba 560 that makes a thumping noise while running. Stops every 10 minutes or so, flashes a red light and says to remove and clean brushes, though brushes are clean. Main cup seems to be empty after running, though there is dust/lint in the filter area. I can see larger debris on carpet and it doesn't pick it up.
I have tried the following: Checked and cleaned the fan to make sure it was running. Removed and cleaned front swivel wheel. Removed both brushes and cleaned them. Removed round yellow pieces on brush ends and found no difference so I put them back on.
  • 954 Answers
Here is a video on those problems: https://www.youtube.com/watch?v=j1vT528_q2U
Here is also a troubleshooting guide:
https://www.ifixit.com/Wiki/iRobot_Roomba_560_Troubleshooting
I hope this helps you out!
Posted on Apr 18, 2017
SOURCE: Brushes are clean, but Roomba stops and says clean brushes
I decided to take it apart and see if I could fix it because even if something inside went "SPROING" and I couldn't get it back together, it wouldn't be any worse than it was already.
FIrst, remove the dust bin part and the brushes. Then, there are four screws on the bottom gray panel which have to be removed first in order to get to the gears which hold the brushes. I did not remove the little sweeper brush on the front, but I just slide it through the hole in the gray panel.
Then in order to get out the orange section which actually holds the brushes, there are four screws which must be removed. The orange section is attached to a blue section. This entire unit comes out by sliding it toward the area where the dust bin goes, being careful not to tear the light gray rubber gasket which covers the side.
Once that section is removed, there are two screws on each side. These screws hold the orange thing to the blue thing. Once the screws are removed, lift up only the side which has the white squares into which the brushes are inserted. These are actually the back side of little gears. There is a face plate on the outside of the orange part on this end. The other end contains a bunch of wires and I was careful not to disconnect any of them.
The face plate has six screws which must all be removed. Use caution when removing the face plate. Hold it up so that all of the stuff doesn't fall out. It has a bunch of gears, little brass looking fittings and grease. Take care to only remove the gears which have the squares which hold the brushes AND do it one at a time unless you like working jigsaw puzzles. I used tweezers and a pin to clean the "gunk" consisting of hair, fuzz, etc., out of the little gears.
Reverse the process to put it back together. Hazel, my little Roomba, played me a happy little song and immediately went back to work. She seems as good as new.
Posted on Nov 20, 2008
SOURCE: roomba keeps saying clean brushes yet are clean!
Remove the Yellow connectors on the end of the brushes and clean around the pin well. If there is too much there, the roomba thinks there is something stuck and goes into clear mode (as if there is a chord stuck).
Posted on Feb 24, 2009
SOURCE: irobot roomba 560
Ah ha!!! After cleaning the brushes umpteen times I worked out that you have to remove the very small yellow pieces (not the other ones which sit on the end) but the ones right on the end and look for hair that is caught on the spindle. No more clicking noise either!
Posted on May 11, 2009
  • 61 Answers
SOURCE: no suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Posted on Jun 03, 2009
pic498
  • 32 Answers
SOURCE: New Roomba 560 beep twice, ask to clean brushes, but no dirt
your roomba is thinking that you need to clean the brushes. if too much load it put on your brush motor--the unit will think that something is wrapped around the brush and slowing down the motor. if you have cleaned your brush and are sure that is not the problem; you need to look for anything else that could be slowing down the brush/motor. If this is inconclusive you need to put your roomba into diagnostic mode by following the procedures in the link below http://swiftracer.com/index.php?myPage=RoombaDiagnosticMode.php
Posted on Jun 15, 2009
Roomba appears to be working fine, goes over the whole house with no trouble, but then house is still dirty and no dirt is in his dirt bin.
if there is dust in the filter and none in dirt bin check to see if brushes are turning, you can do this by running the roomba with bin out, if not turning clean thoroughly, remove yellow tips on ends to check for trapped hair, replace brushes and turn them manually in one direction a few times and then run roomba again, you may need to do this a couple of times
Sep 08, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba 530 makes a thumping noise every secondand stops with a message to clean he brushes. I have cleaned the brushes and filter but to no availe the thumping continues.
You also need to pull off the yellow bearings from the end of the brushes (one on the brush one and one on the rubber one) and remove hair from the axle there.
May 20, 2010 | iRobot Roomba 560 Robotic Vacuum
IRobot 560 Roomba making thumping/light clicking noise.
under warranty take it in for warranty repair or exchange
you try to fix it and the warranty is voided
just tip it upside down and check for threads wrapped around brushes and rollers / wheels
Nov 22, 2017 | iRobot Roomba 4210 Bagless Robotic Vacuum
Irobot stops after a few minutes and says plaes
soooo, what is not understood here ?
turn it over, open brushes cage, take each brush out and clean it.
In addition, also clean the sides from any dirt/hair that may stuck in its pivots.
good luck
Avi
Apr 07, 2010 | iRobot Roomba 560 Robotic Vacuum
Jun 13, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
No suction on Roomba 560
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
Irobot roomba 560
Apr 12, 2009 | iRobot Roomba 560 Robotic Vacuum
Problems with roomba 530
before taking apart your Roomba read this!!! First to see if it is a defect or really the brushes, take the brusehs out and run roomba with out them. If you still hear the clicking/ thumping then try taking it apart or call roomba. But if the clicking/ thumping goes away when the brushes are out you're in luck! Take the brushes. The brushes have little yellow nubs... those come out. pull them out, and you will see a lot of hair waiting for you. clean all of the hair out ( tweezers are wonderful for this). Once they are cleaned out put the yellow nubs back on. Put your brushes back in and you're Roomba will be back to business in no time!!!
Jun 06, 2008 | Roomba Robotic Floor Bagless Vacuum
iRobot Roomba 560 Robotic Vacuum Logo
447 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
