Question about KitchenAid 24 in. KUDS25 Built-in Dishwasher
Kitchenaid Dishwasher model # KUDS25SHBS1 has started making noise. Noise happens when unit is draining so perhaps its the same mechanism that houses the grinder. Can definetly hear a clicking as something spins around to drain the unit. I have removed the washing armature and plastic skirt around bottom and felt underneath the skirted area, but don't feel anything caught or jammed. Noise is getting louder as more draining cycles are being utilized (i.e. as we use the machine more). Anyone have an idea about how to fix? It the bottom piece in the dishwasher removable? The plastic piece with the fine mesh and the flat tube thing running down the back of the inside of the machine? Are these items removeable and how?
  • 901 Answers
Looks like motor noise. Check the pump.
Posted on Jun 01, 2010
The child lock light flash
Hello. Your Kitchenaid unit has the child-lock enabled. Look for a button(or set of buttons) that has a small lock symbol beneath or the word "lock". On most models, you have to push and hold the button(s) until the lock light goes out(usually about 3-5 seconds). That should disable the lock and the unit should operate normally. I hope this helps you!
Dec 18, 2015 | KitchenAid Dishwashers
Hobart LXiH error E4 AND part makes noise when OFF
test this steps and fix it. GOd bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Jul 22, 2013 | Hobart Dishwashers
Hobart LXiH error E4 AND a part makes noise when off
test this steps and fix it. God bless you
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
Jul 22, 2013 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Kitchenaid dishwasher making funny noises while running
HI. this sounds like a busted impeller in the pump housing. there are two impellers. one for the wash and one for the drain. the drive shaft will strip the impeller center nut, causing this noise. I would inspect the pump housing for lose impeller action. replace the faulty impeller if found to be damaged.
Jun 11, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Kitchenaid dishwashes makes wining noise during wash
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
Mar 13, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Loud grinding noise when washer is draining
something in the impeller housing. not usually serviceable. not sure if that unit has two pumps. you could look underneath the tub and try to determine that, and where the noise is coming from.
i am confident the issue relates to a pump unit.
good luck
mark
Oct 22, 2007 | KitchenAid KUDR01TJ Dishwasher
Briva In Sink Dishwasher Stopped Working!
With a dead unit like that it could be pretty indepth but eliminate the easier things. The unit sould have a fuse that can be checked.
Jun 05, 2007 | KitchenAid 40 in. Briva KIDS42EPSS...
Dishwashers Logo
487 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
