Question about Weber Genesis Gold B Premium Grill
Where can I find a replacement lid for my weber genesis gold grill?
    Guru:
  • 1,051 Answers
You'll have to get it directly from Weber.
Posted on Jun 01, 2010
Bought a weber genesis 320 Problem with the Weber Genesis E-320 Propane Grill bought a weber genesis 320 in US and need to replace the hose / regulator that it fits to German LP gas cylinders. Which...
Normally, at least on an American grill hose/regulator assembly are a universal fit. And both ends of the hose have female couplings. I would think it would be the same on German Models too. For the connection to the grill, the hose coupling size is 3/8" ID.
May 08, 2011 | Weber Genesis E-320 Propane Grill
How do i change the battery in my weber genesis grill igniter?
just a stab in the dark but my grill has the battery in the ignitor button itself just unscrew the lid and replace it i hope this helps
Jun 28, 2010 | Weber Genesis E-320 Propane Grill
We have the Weber Genesis Gold and it seems to be burning itself. Even though there may be nothing on the grill and we've given it plenty of time to burn off anything that may be left, there is a thin...
My Genesis after a year or so begin to blister the inside of the lid
Also if you BBQ with lost of sauces your flavor bars could be your issue Try celaning them
Mar 08, 2010 | Weber Genesis Gold C (NG) Grill
Where can i get a kit or info to change a genesis gold b lp 110101 to natural gas.
Give their customer service department a call at 1-800-446-1071 and they'll be able to tell you if the conversion kit is available for that specific grill. If the grill is old, there may not be a kit. In that instance, you could simply purchase a new grill, or try one of the specialty grill shops that sells replacement parts.
Mar 03, 2010 | Weber Genesis Gold B Grill
How to Clean Weber Gas Grill Lid
you can only use oven cleaner on enameled hood not on the cast painted parts like the body and sides of the hood those you can scrape and vaccum or brush
Jun 28, 2009 | Weber Genesis Silver C Grill
Weber won't get very hot
Safety valve needs reset.
  • Close the LP tank valve
  • Turn all burner control knobs to the OFF position
  • Open the grill lid
  • Turn the LP tank valve until it is completely open
  • Wait several seconds
  • Turn the front burner to the HI/Start position
  • Press the igniter until the burner is lit.
  • Turn remaining burners to High
  • Close the lid.
  • The grill should preheat to 500-550 degrees in 10-15 minutes
I called Weber and the rep walked me through the reset. All grills made after 1996 have this bypass valve.
Jun 21, 2009 | Weber Genesis E-310 Gas Grill
Weber Summit Grill Igniters
I contacted Weber and they sent me a complete igniter system. I will have to install it.
Oct 06, 2008 | Weber Genesis Gold B Grill
Gas grill not lighting
Sounds like you have a faulty regulator. If you replace this make sure that you get a replacement of the same size.
Jul 17, 2008 | Weber Genesis Gold B Grill
Weber Genesis Gold B Grill Problem
Could be partially clogged burner openings (jets).
Remove the cooking grates and the flavorizer bars. Obtain a BRASS brush (like used to clean white-wall tires) and brush the burner tubes from side to side and up and down along their entire length to remove all corrosion from the jets. Also the cross-over tube.
Before replacing the flavorizer bars and cooking grates, ignite all burner tubes and check to see the flames are all of about equal length and intensity.
If this isn't the problem, check the screens at the right-side ends of the burner tubes to be sure they're not clogged.
If the burner tubes are all clean and some don't ever ignite, the problem could be in the valves/manifold.
Jun 17, 2008 | Weber Genesis Gold B Grill
Weber Genesis Gold B Premium Grill Logo
376 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
