B93-366 Indoor Unit Ours is mounted on the wall in a new room addition (3 years ago). Has worked fine. Used it with remote control a few days ago. It worked fine. Turned it off with remote control. next day would not turn on at all. Replaced batteries in remote. Didn't Help. Tried manual override on the unit itself. Still nothing. We have misplaced our manual. Any suggestions?
    President:
  • 1,902 Answers
You will have to remove the front panel and check the fuse to make sure that it did not pop. Also check your breaker switch to make sure that your breaker did not pop. Those can be your really only two issues
Please rate
Posted on Jun 01, 2010
Why does my Fujitsu ductless AC turn on by itself and without me using the remote control?
You would have to figure out what is sending a signal to its receiver. If no signal is being sent then its the signal then it may be the receiver(board) in the indoor unit. Also, other remote controllers for, TV, fans,ps3 or ps4, DVD player, dish ect... have the potential to interfere. I've had/seen a Hunter ceiling fan turn a window unit on 5 mins after you turned on the ceiling fan. Of course the customer was hard to convince. If you want, try removing all remotes to the other side of the house. That's the cheapest thing to try. You can check all wire terminals and grounds to ensure they are tight. Other than that? Work safe!
Jun 26, 2015 | Fujitsu ASU9RLF Hybrid Flex Inverter Wall...
Our Kreisler air conditioner is rarely used, is 7 years old and will not switch on. The batteries have been renewed on the remote. Could it be the sensor in the unit? Do I need a service man?
The first thing I would suggest it to verify that power is provided to the unit. You should get a display on the face of the indoor unit if there is power. If there is power, try turning the outdoor unit off for a few seconds and back on to reset the controller. If your unit is like I think it is, the indoor unit receives its power and control signal from the outdoor unit, then the remote utilizes a rf signal to control the system. Also try new batteries in YOUR remote.
Jan 04, 2015 | Heating & Cooling
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
I don't know what model my fan is, but it's only 3 years old and suddenly two days ago the light and fan quit working. We replaced the light switch on the wall-nothing. Took apart whatwe could of the fan...
That may be, because you were using the Remote Control to operate it, but then turned off the wall switch instead of turning it off using the Remote Control.
Turn the wall switch back On and try to get the Remote Control to take back over the operation. If that solves your problem, in the future you will know to turn off the fan and lights with the remote, before turning off the wall switch.
Hope this helps solve your problem. My wife had to learn the same way with ours.
Feb 04, 2011 | Hampton Bay Heating & Cooling
We have not used our Daiken wall mounted inverters since the cold days of winter, and now the remote control will turn on the lights, but nothing else goes on and no cool or warm air will come out. The...
Normally, there will be error code whenever the problem arises. But if you couldn't see the error code, depends on counting number of flash, we can diagonize. Any how, with your limited statement, I hereby try to solve your problem.
Indoor Room thermistor error 1time Flashing
Indoor in-piping sensor error 2times flashing
Communication error between in and out 5times Flashing
Indoor Out-Piping sensor error 6times Flashing.
Hope, this helps you.Thanks.
Dec 25, 2010 | Fujitsu Heating & Cooling
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
