Question about GE WBSR3140DW Top Load Washer
What I do to open the washer machine? - GE WBSR3140DW Top Load Washer
  • 3 Answers
Spring clips secure the front panel. They are about 3 or 4 inches in from the corner, and can be seen by looking thru the crack between the top and front panel. Use a putty knife to push each clip to the rear, while pulling the front panel, on that side, foward. The panel assembly will then lift up and off the lower metal tabs. The top does not move.
dwm1095@yahoo.com
Posted on Jun 01, 2010
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Water pours from under washer GTWN2800DOWW
4 inch from corner push in with putty knife . will open front panel
Sep 16, 2014 | GE Washing Machines
No hot water supply
If you have the Hot Water open at the outlet and you know for certain water flows from the source to the washer; then a Valve is not opening into the washer. The valve is controlled by the washers circuit board. This solenoid is electrically activated upon command, and if that instruction gets to the valve it should open and close. Failure could be either the Valve or the Command Center.
Mar 25, 2014 | Amana ALW880WH Top Load Washer
I have the LG wm2487h*ma front load washer.My washer is filling up with water when not in use. When I wash a load, the water does not go in the washer. Have opened the door thinking the wash cycle is done...
The problem would appear to be the water inlet solenoid valve.
The valve is not operating correctly for some reason allowing water into the machine even when switched off
Sep 02, 2017 | LG WM2487H Front Load Washer
Electrolux washer door won't open
Hi.
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
The door is not opening
1. the door will not open if in the sanitary cycle.
2. the door will not open if the water level is too high. (open access door at lower left on front of machine and use the hose there to drain water out of washer.
3. the door will not unlock without power to machine except for the following:
4. unplug machine, remove top cover by removing bottom screws from plastic clips on back of washer top, then standing in front of machine, using the palms of your hands to sharply push back the sides of the washer's top about 2 inches, allowing top to be lifted off machine. reach down to door latch and manually move latching arm on door latch to allow door to open.
Mar 06, 2011 | LG Washing Machines
L g washer
is water still in the machine. if so check the pump (the little door at the base of the machine) first use that little tube to drain the water. there is a safety feature on front load washers that does not allow the washer to open if it is full of water
Dec 20, 2008 | Hoover H130E Front Load Washer
Door on washer will not open
Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
Nov 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washer Door will not Open
door lock blown motor problem for the noise appliance doctor
Jan 29, 2007 | Hotpoint WMA58 Front Load Washer
GE WBSR3140DW Top Load Washer Logo
65 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
