Question about Peg Perego John Deere Gator HPX Ride on Toy
The batery notake charge - Peg Perego John Deere Gator HPX Ride on Toy
    An expert whose answer gotĀ voted for 100 times.
    Habit-Forming:
  • 156 Answers
It could be the battery or charger which you can get at
http://www.mypegperegoparts.com/ They might be able to let you know if it is the battery or charger.
hope this helps
Posted on Jun 08, 2010
Mig wire keeps jamming in the supply line
If the welder is new it should tell you what gauge of wire you need. Usually that is the problem if notake sure the line doesn't have any kinks. Also make sure you didn't weld your tip closed.
Jan 19, 2015 | Welding Tools
I have a 2004 Kawasaki zzr 600 that does not keep the charge longer than 2 days. What is causing this problem
hi, you probably have a "almost dead" batery, but in order to properly check, proceed as folows:
1 - give the batery a full charge
2 - disconect both cables (+) and (-) from batery
3 - check charge and see if batery holds it - a good batery must keep 12,7 to 13,2 volts for a very long period
If after this test,considering that batery is ok, then chek your wiring loom for ground losses
good luck
Sep 13, 2011 | 2004 kawasaki ZZR 600
How to charge new battery in my laptop
as i do not know what laptop we are talking about here i asume its not a notebook
if it is the time is slightly lower (6-8 hours)
a normal lap top 10 - 12 hours.
some super batery laptops come with an own (long) guide how to keep the batery alive.
to keep the batery alive a long period of time charge it from 50% not when its at critical.
If u can take out the batery when you are using cable and its fully charged it also has a longer life time. or just take out the cable when its at 100% and recharge it when it gets to 50%
dont have your computer in the lap it can over heat the computer/batery and the lifte time gets even lower.
Aug 24, 2011 | Dell Inspiron B120 Notebook
Change or charge battery
Hi, depending on what happens when the batery is fully charged, does it go flat aftera day or two or does it stay charged? If it keeps going flat take it to a battery centre to test the amps that the batery makes. I f the amps is out the battery is dead.
But
If the batery is fine after charged and the amps is correct and the bike still makes the batery flat.
Then you have to replace the Stator and the magnitor.
Dec 09, 2010 | Yamaha YZF-R1 Motorcycles
Acer aspire one battery light flashes orange. When booting after a few seconds it shutsdown. Now all lights stay off. Can this acer netbook work without batery ? It doesn't seem to charge the batery
Finally I got it working again, after a lot of try's (just put the plug in for a few hours) the led was red again for a brief moment, then it starting to flash orange again.
I looked it up on a lot of forums, the problem is that the (old) bios doesn't charge the batery anymore when it is deeply discharged.
So I put the plug in and out for about 10-15 times , and the brief moment it is not flashing it's still charging. Until it is not deeply discharged anymore and then it is charging the batery like it did before.
But I still don't understand why it is not working without the batery inserted ??
Nov 14, 2009 | Acer Aspire One PC Notebook
How long to charge battery?
bateries have their own specifications.You can read it on the label.But,most of all it must be charge from 12-15 hrs. on its very first charging ( for a new battery) and later on or for the second time and so on, you may charge it 2 to 4 hrs.,sometimes 8 hrs..Leting you know,a battery can be charge even a short span of time,for example is 30 minutes only.In that 30 minutes try to measure its stored volt using a volt meter or a multi-tester,and the result is laready 12 volts (if your batery is 12 volts.)do you believe that? YES.! because a battery is so easy to store power.But,the problem is that its so easy to drain its stored power.You know why?because the current or amper of the baterry is still weak that the given specification.,.So,for short explanation,the longer time you charge your batery equals the longer time to drain the power.For example: when you charge the batery within 4 hours,thus the batery will be drained after 4 hours.
Oct 31, 2009 | Black & Decker 8 Inch 12 Volt Cordless...
I got Nokia N99i chinese version cellular phone with 2 batteries, one battery worked for 3 months & now charging isn't holding & other battery can't charge since bought. How can i buy a new battery...
Men you really got a problem!
ok Try Ebay, if not www.alibaba.com sure you can find the batery there.
Other ways:
the batery its not charging at all?
you can buy a Universal Batery Cell phone carger, these ones got the ability of charge some times baterys whit thiis kind of problem.
Make an adaptation from other batery (just look details as Voltage, amps) sometimes its require soldering directly to your phone :S (pretty extreme)
Oct 17, 2009 | Cell Phones
Problems with phone
it seems like that.but it can be solved.go to the samsung care & ask to restore the phone and update its software.
Dec 24, 2008 | Samsung SGH-J600 Cellular Phone
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
Peg Perego John Deere Gator HPX Ride on Toy Logo
74 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
