Question about E-Machines Computers & Internet
Just installed windows7 but now i got no sound!!! updated driver but still wont work!help!my device is displayed as realtek97 audio drive.... pleeeeease
  • 503 Answers
I would suggest you go into the bios settings and see if the onboard sound is on or off, since the realtek sound system if memory serves me correct is in fact the onboard sound system, which will do for most common things but you will never get a high fidelity sound out of it.
Posted on Jun 01, 2010
Camera and video are not displaying when i intalled windows7 ultimate and 8 enterprise
This sounds like a driver issue. You could try checking the maker's website to check if they have any updated drivers and installing them. If that doesn't work then try uninstalling the card from device manager and doing a restart. Windows should recognize the card and reinstall. It should ask if you have a disc and if you do then try using the drivers that are on the disc. The last thing you could do if these two suggestions don't work is to disable the onboard sound card (if there is one) by turning it off from the BIOS settings. Sometimes two sound devices can conflict.
Dec 28, 2013 | Sony Computers & Internet
My lg laptop is not sounding out, and it shows sound device not detected
Isaac, their are so many reasons why the speakers wont sound. since its showing sound device not detected, it is possible that the for your audio device is not installed. if you use a windows7 operating system, on the start search type device manager when it comes out , click on it. go down to audio rightclick and select update drivers. if searches and didnt find it, then insert the driver disc your system came with. this should do it.
another reason why the speakers wont sound is if their is a hardware faliure. in this case all you have to do is see a technician or a computer engineer.
am sure this will do.
cheers!
Aug 23, 2011 | Computers & Internet
Sir! I have HP 7600 System. I installed Windows7 Ultimate, but it has no sound, I have sound problem, I don't know what is the reason. I did every thing such as Updating the driver, deleting the...
1) Download the most recent windows vista 32bit audio drivers from http://h20000.www2.hp.com (or navigate to the page on HPs website yourself)
2) Once downloaded, run the file. The install will fail but will create the folder "swsetup" on your "C" drive.
3) Open up control panel --> system and security --> Device Manager
4) Under "Sound, Video, and Game Controllers" right click the audio device that appears and choose "Update Driver Software"
5) Click "browse my computer for driver software".
6) Click "Browse" and navigate to "C:\swsetup\SP35288\Vista", click "OK" and then "next"
7) The driver should then begin installing.
Aug 10, 2011 | Computers & Internet
I use windows 7. my mother board is mercury pi945gcm . i installed sigmatel audio drivers. but they are not working properly. i got stacgui:speaker manager plugin failed in a alert box. result for this...
this like you did not install sound driver properly
check at device manager
is there any yellow mark at device manager?
if yes at tha yellow mark right click the chose update driver
insert cd driver and follow the instuction until finish
if this successfull the yellow mark will disappear and you can navigate the sound device as you like
Mar 15, 2011 | Computers & Internet
Can not find audio driver....
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 23, 2011 | Computers & Internet
I have a asus motherboard p5pe-vm (865) . audio driver of motherboard are not work in windows7. please explain what i do.
did you try downlaoding the audio drives from ASUS website or try going to control panel then device manager then look for your sound drives then right click that driver and try to update the drivers there. If that doesnt work try uninstalling it then reinstall it hope this help you out
Nov 10, 2010 | ASUS P5PE-VM Motherboard
I recently installed windows7 ultimate but after completion audio devices are not working sound is not coming i heard windows7 ultimate has a default audio drivers please solve my problem
Try to identify your audio hardware and go to their website to download compatible driver for your audio device. For example you have a Realtek Audio device, go to www.realtek.com/downloads and look for the drivers for your device.
Tip:
Most computer companies uses Realtek Audio Device that's why I set it as an example.. husssh... Enjoy!
Aug 31, 2010 | Lenovo 3000 Y410 Notebook
Unable to install realtek audio software due to
if it is truly software and not hardware then i reccommend uninstalling the driver that you have and downloading the newest drivers from realtek's website or if it is an onboard sound device (made on the motherboard and not a stand alone card ) get the driver from the motherboard website as it may have other features needed for that particular appliaction
Mar 27, 2010 | Computers & Internet
Conexant audio when updated displays no media device to support.
go to your motherboard's web site and download the latest drivers, make sure it mateches the right version of your windows.
do you have x86 or 64 version of windows xp in other words do you have a 64 bit processor.
what service pack do you have with windows XP, SP2 ??? or SP3 ???
Mar 22, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Sound not coming
You will find the correct drivers by browsing to Compaq's home page and submitting the model number of your Compaq
Nov 29, 2008 | Compaq Audio card Sound Card
Computers & Internet Logo
59 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
