Question about Danby DPAC7099 Air Conditioner
I have a Danby portable air conditioner: DPAC7099. What is the garden hose for?
  • 8,197 Answers
The drain hose is to drain the unit when in dehumidifier mode. You can get the manual on the link below just enter the # code then click on download manual. Page 10 of the manual.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck
Posted on Jun 01, 2010
Where can in get a set of exhaust/intake hoses for a danby dpac120068 air conditioner
Is there a reason not to just go to the Danby site? Support Danby includes phone support, email and "Find Parts" Even if their source is out you should at least be able to find the correct part number, then Google Danby (part number).
You could also look to see if generic flexible vinyl tubing/hose can be substituted. It's doubtful that Danby created their own hoses.
Jun 09, 2016 | Danby Heating & Cooling
Danby portalbe air conditioner model dpac7099
Go to www.retrevo.com and click on manuals. Once you locate your product it should let you download it for free
Jun 26, 2012 | Danby Heating & Cooling
Cant find manual. How do you adjust tempature on this ? Thank you
First make sure that the unit is in Cool mode. (Press the Mode button: the choices are Cool, Dehumidify, Fan and Auto. You will see the mode at the top of the LCD display - Cool to the left and Auto above the temperature display) Then press the + or - buttons (or the up/down arrows on the remote) to reach the temperature that you want the unit to maintain. If you press both the up and down buttons together, the current set temperature will display for about 5 seconds. Then you can set the unit back into the Auto mode so that the mode and fan will switch on as needed.
Danby has the manual for the DPAC7099 on their site: http://www.danby.com/product/DPAC7099/4 . See the Literature tab. The direct link is http://www.danby.ca/cms/uploads/products/en_manual/dpac7099_web.pdf .
I hope this helps.
Aug 02, 2011 | Danby DPAC7099 Air Conditioner
I need to replace a hose on a Danby portable airconditioner model # DPAC120068
The first place to start is with the manufacturer, Danby 800-496-6049. Or take a section of the hose with you and go to your nearest home center and purchase a similar hose (same diameter) and use all the existing fittings that you have, to remount it with the new hose. There are several types available that will work well for this type of application and probably last longer than the original hose did.
Hope this helped you. Please let me know. Thanks.
Jun 08, 2011 | Danby 7,000 BTU Portable Air Conditioner -...
Danby AC DPAC7099. I need an exploded view or parts list. I can't find it anywhere. Basically what I need is the float assy..
Here is a link to your Owners Manual, in case you have misplaced yours, as well as a contact number for Danby Customer Service, where you can also purchase the part.
Customer Service: 800-263-2629
Hope this helps you get the float assembly you need.
May 09, 2011 | Danby DPAC7099 Air Conditioner
I have my hose plugged in and its draining alot of water. I am just using air conditioner
Depending on you ambient humidity, you can get a lot of condensate water. Think of it this way, your air conditioner is trying to cool the air, just like ice cubes in a glass. Wouldn't you expect to the outside of the glass to be dripping wet if you set it out for a while?
Jul 21, 2010 | Danby DPAC7099 Air Conditioner
Water spill
1) Press the POWER SWITCH key (Fig. G) to
switch the unit on.
2) Press the MODE key (Fig. H) until the DRY
indicator light illuminates on the control panel
(Fig. I). Each depression of the MODE key will
advance to a different mode setting (Cool -
Dehumidify - Fan - Auto )
3) If the room temperature is > 25°C (77°F), fan
speed can be adjusted. Press the FAN key (Fig.
J) to select the desired FAN SPEED setting. Your
selection will appear on the control panel. Each
depression of the fan key will advance to a
different fan speed (High - Med. - Low )
as shown in Fig. K. Otherwise fan speed is fixed
to low.
Note: The warm air exchange hoses must vent
inside the room when using Dehumidify mode.
Jun 01, 2010 | Danby DPAC7099 Air Conditioner
Danby dpac120068 Air Condtioner, where does the hose go? and do you fill the tank in the back with water?
hose goes into a bucket or out a window, drained, etc. it's the drain hose for the condensation. alternatively you can use the tank to catch the condensation, which must be emptied periodically.
Jun 14, 2009 | Danby Portable Air Conditioner
Danby DPAC7099 Air Conditioner Logo
322 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
