Question about D-Link WUA-2340 (ASKU55774) Wireless Adapter
The light is not flashing.
Does this mean it is broken?
    Problem Solver:
  • 14 Answers
It might probably be broken or it mgiht have too much files in it. You can try to erase some files and add new ones or just buy a new adapter.Hope this helped you!
Posted on Jun 01, 2010
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
Why signal light wont turn off in 94 325i BMW
Do you mean it won't automatically switch off after you turn, or do you mean it stays on, either flashing or just permanently on?
If it's the 1st one "doesn't automatically switch off after turning" it sounds like your turn signal stalk is broken & needs replacing.
If it's a case of the light just continuing to flash or stay on well then it could still be your signal stalk or the relay which times the lights to flash on & off.
All these bits can be purchased for little money on eBay
Mar 17, 2014 | 1994 BMW 5 Series
My camera won't take pictures with the flash on and when i try the red light just blinks. only takes pictures with no flash.
When your flash light (I mean the part that gives the flash) or the capacitor that stores the power for the flash are defect. you won't see a flash. When a red light comes on, when actually the flash should fire, the most likely the capacitor is defect. The electronics sensed it could not reach the voltage needed to fire the flash.
It also could mean your battery can't deliver enough to charge the capacitor, but is that was the case the battery indicator should tell you.
Jan 20, 2014 | Nikon COOLPIX S230 Digital Camera
What do the flashing blue lights mean on front of refrigerator?
Flashing blue lights on front of what model Samsung refrigerator?
Jun 12, 2013 | Samsung Refrigerators
Oil light coming on and stop light flashing
hi doesent mean that there is oil in it check that first then check to see if the cable on the oil sender unit usually on the sump some where hasent been knocked of or broken hope this helps ivan
Sep 26, 2012 | Peugeot 307 Cars & Trucks
My projector is overheated with temp light flashing. how can I fix it?
If only the TEMP light is flashing, then it means the fan has broken down. You will need to send it to Dell to get it fixed.
May 09, 2011 | Dell M409WX Projector
ALL FLASHING LIGHTS
hi there.
if all lights are flashing, turn off the printer and unplug it from the power source, wait for about 10minutes. while its off, check for obstruction or paper jam inside the printer, take it out, if theres nothing in there, good, turn it on, if still all lights are flashing,
that means, the printer is broken, call epson to get a replacement printer if the product is still 1 yr. from the date of purchase, if it is more than a year, most probably, thats out of warranty,
Feb 17, 2010 | Epson Stylus Pro 9800 InkJet Printer
We have 80,000 miles on our 2000 Millenia with the following problem, 1.Flashing engine light, 2.Runs a little rough at idle, 3.The steering doesn't feel right..not stable or hunts?
The flashing light and rough engine means a spark plug(s) misfire. I've had that issue before. The steering could be a few things. The ball joint or wheel bearing might be broken or the axle could be broken. I replaced my wheel bearing (pot hole) and the steering was fine. However, I also had to replace my steering rack prior to that incident.
Nov 09, 2009 | 2000 Mazda Millenia
Flashing red power light Only
This means it is broken down. You need to call playstation, to find the number go to www.playstation.com. My friend had the same problem, that means there's something wrong with it.
Jan 30, 2009 | Sony Playstation 3 (PS3) Console
Canon ip1300. Three orange flashes, one green.
Hi emdos,
Did you mean blinking three times in Orange?. Well, the problem is paper jam error occurs in your printer. First, check if any broken paper inside printer. If it so, remove broken paper. If problem still persist, it seems that drive assy broken or paper feed sensor fault. Find more useful article about this below.
Soruce:
Canon Inkjet Printer Forum
Nov 26, 2008 | Office Equipment & Supplies
D-Link WUA-2340 (ASKU55774) Wireless Adapter Logo
108 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
