Question about Miele Novotronic Premier 500 Front Load Washer
Miele novitronic w830. Drain wont work. I've cleaned the outlet of dirt and the wheel inside the outlet is spinning freely. Reggadles, red light comes up.
  • 177 Answers
Have you tried checking the drain spigot under the sink where the waste hose connects as it can be blocked at this end?
Try draining the unit into a bucket instead of the sink this will eliminate the washing machine as being the problem if it works ok.
is the drain pump actually turning? select drain or drain spin and have the fluff filter (outlet) removed so you can see if it is turning. if it isn't turning there maybe a broken wire to the drain pump causing it not to turn or the drain pump is jammed with something although you mentioned you could spin it freely.
hope this helps
Posted on Jun 01, 2010
Miele washing machine wont spin or drain
clean your filter first then check there is nothing in the pump area
Jan 22, 2014 | Miele Washing Machines
Hi there, my Miele W 1903 Novotronic is not draining nor spinning and the drain indicator light is flashing. I have cleaned the filter and the pump seems to be turning freely. Help, please!
Please ensure you have used the proper procedure on page 26 of the manual for cleaning the lint trap.
MANUAL - LINK
Unplug the unit for 20 minutes if turning the Dial back to Start/Finish does not reset the lamp.
Thanks!!
Aug 03, 2011 | Miele W1903A Front Load Washer
My miele is saying check drain - what should I do?
You probably have foreign objects in the drain pump. To access the drain pump, open the cover on the lower left hand side of the unit. Once thats open you will see the drain pump. Turn the knob to open drain pump. There will probably be water still in the pump so you may want to have a small container and some towels handy. Reach inside the pump and clean out any foreign object. The rotor is located in the back of the pump, stick your fingers inside and make sure it spins freely. That should take care of your problem.
Mar 28, 2011 | Miele W865 Front Load Washer
Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
Why wont my dishwasher empty,it goes through all the program but just wont empty,it was fine when we were using it before we moved.
The drain pump motor is in line with the outlet pipe. First check if the outlet pipe is not blocked or obstructed. The motor can be tested by removing the 2 electrical push on connectors and connecting mains supply to the 2 terminals. If the motor spinns it indicates that the motor is OK and that the fault is then with the electronic switching circuit (not normaly a home repair). If the motor does not spin it indicates that the motor is open circuit and needs replacing. (easy job). You can also spin the motor small cooling fan by hand just to determine if it runs freely like it should and is not obstructed by dirt inside the water channel of the pump.
Mar 20, 2010 | Dishwashers
Miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
Apr 05, 2008 | Washing Machines
Miele W830
I have exactly the same problem - what was the answer ?
Mar 15, 2008 | Miele Novotronic Premier 500 Front Load...
Both the intake and drain lights are flashing
There are several simple solutions, one is reading the instruction manual. Check Intake: is any water entering? is it slow? This machine filters debris from the supply water so check the water intake filter. It is inside the end of the intake hose end against the home. Rinse it clean.
Drain: The same fault appears if the drain is clogged. Check if the lint trap is perfectly clean. Check the impeller (a set of fan blades) behind it spins freely. If buttons or coins get in there they can break off the fan blades and you can't drain water. Check the end of the drain hose if it drains. put it into a bucket or tub basin to observe how strong it pumps. Call Miele if these tips don't work. Be at the machine with Model and Serial number ready.
Dec 16, 2007 | Miele Touchtronic W1113 Washing Machine
Miele Novotronic Premier 500 Front Load Washer Logo
660 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
