Question about Sony DVP-NS775V DVD Player
I have a NS775V DVD that is no longer recognizing the presence of a disk. The tray slides in, but nothing displays on the front panel LED display; the on-screen display doesn't change, but all the front-panel lights ("progressive", "super-audio CD", etc) light up. When on, but with nothing in the tray, it displays "NO DISK" and I am able to access some setup and parental control settings. All the indicator lights are on. This happened once before, about a year ago. (There was one difference, the LED display showed "NO DISK" -- I don't recall what the indicator lights statuses were.) A local Sony service rep resolved the issue -- apparently by resetting something. He told me this was a common memory-related issue, that happens if you leave a DVD inserted for too long. The service cost me $75, which is why I'm reluctant to bring it back to him, as it's less expensive to replace it. He didn't replace any parts, and I got the distinct impression that what he essentially did was "reboot" the player's software. If that's the case, I would like to know how (the technician that I spoke with last time is not available). I'm presuming it entails either some internal reset button, or unplugging some component or possibly even as simple as a front-panel button combination. The user manual doesn't seem to have the information; it talks about resetting the user preferences but nothing about a full "reset to factory defaults" that I could find. If so, I feel I am competent to perform the task myself. I am technically competent to the extent that I can safely open the case and find a reset button -- I can certainly deal with a front-panel combination. Can you help? Thanks, Jeff Mark
  • jeffm23 Jun 01, 2010
    I'll try cleaning the lens in the morning, but the tech last time really made it sound like he was resetting memory in some sense. The way I recall, he described it as a problem with memory not clearing -- the memory that stores where in the DVD you were when you stopped, the so-called "Multi-Disk Resume" feature. He advised me to always press the "stop" button twice to clear the memory, and that I ought not leave a DVD in the tray overnight, that this is what triggers what he seemed to say was a known problem. And indeed, what happened this time was I watched part of a DVD, but forgot about it and left it in the player -- when I returned to it after a few days, the player didn't seem to know it was there.
    No disrespect to Rylee, but his response seemed a bit generic, unsure and unresponsive to my particular issue, and I'd like another opinion. Like I said above, I recall that the technician last time told me, or at least implied, that this was a known problem. If that's true, it's recorded somewhere. If it's not true, a definitive statement to that effect should be possible.
    Thanks again.
  • Shahid Electronics
    Shahid Electronics Jun 01, 2010
    Silverdragon What are you saying? your answer is really confusing, talking yes and no at same time.
  • Sony Master
  • 12,061 Answers
Http://www.givemefile.net/smanuals/dvd_players/sony/dvp-ns775v.html
http://www.retrevo.com/support/Sony-CDP-CE275-CD-Players-manual/id/423ci257/t/2/
Top link is your service and repair manual, below that is your user manual. Usually when this happens in the ones bought into my shop, it is the actual DVD player itself. This must be replaced, there really are no replaceable "Components" most things are dealt with by replacing the faulty, item, or Board. Usually, what happens is the laser head. Sometimes a simple clean with a head cleaning DVD will work wonders, so you may like to try that first before you go any further. but if that's no good, then no doubt, the assembly has burnt out, due to the control circuitry that ramps the current up and down, while the DVD is being used, either in burn mode or read. Seldom will any type of "Reset" cause any return to functionality, if it truly wasn't reading or recording before. Also may symptoms are the same or similar, however the causes may be many and diverse. Really all the unit can do is go, or not go, these are not exactly definitive symptoms. Anyway please use these manuals to reset everything and be able to troubleshoot your problem.
Posted on Jun 01, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Dont think there is a reset button in this unit. To start with try running a lens cleaning disc, if that does not work then you have to open the unit and clean the lens with a Q-tip dipped in alcohol. If still the issue is not resolved then the lens should be replaced however, replacing a lens will cost you around $75 and a new one will cost you around $50. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
When I use the timer to record a TV show with my DVD-R155, unit locks up.
If you can afford it purchase a TIVO. I had a a video and dvd player and it drove me mad. This unit records 2 programs at once with just the press of a button.
you can watch tv at the same time. Also you can rewind situations on live tv to watch it again. Top unit. I am 73 and I have no problem using it. Love it!
Dec 07, 2011 | Samsung DVD-R155
Panasonic DVD recorder won't recognize any disk inserted in tray
I am just wondering if you found the solution to this problem as it has happened to ours.
Regards
Oct 11, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
When previewing my video in adobe encore, it looks fine but when i burn to dvd, the video jumps everytime the camera moves. What can i do?
This is everything from adobe encores website.
Playback issues in Adobe Encore DVD 2.0 have a variety of symptoms. The following symptoms may occur when you use the preview feature, when you play video in the Monitor panel, when you play to an external device, or when you edit a menu or slide:
-- Video or audio exhibits stuttered playback.
-- Video or audio cut in and out.
-- Audio is out of sync with video.
-- Video displays as black in the monitor panel or after burned to disc.
-- There are general redraw problems in the user interface.
-- Encore DVD returns the error message, "Invalid requested time," when you transcode a file.
Beginning troubleshooting
1. Test the DVD on a variety of players.
Not all DVD players behave the same way. By testing the DVD on a variety of players, both set-top and software, you can determine if the problem is related to the DVD itself or just the player.
2. Make sure that the system meets the requirements for digital video.
Video may not play correctly if your system doesn't meet the following requirements:
-- Intel Pentium 4, 1.4 GHz processor or faster
-- Windows XP Professional or Home Edition with Service Pack 2
-- 512 MB RAM (1 GB or more recommended)
-- Hard disk with at least 16 GB of space for installation and ongoing work (RAID recommended for HDV/HD editing)
-- 1280 x 1024 or greater color monitor resolution, 32-bit display adapter
-- QuickTime 6.5 required to support import and export of QuickTime files
-- Supported DVD burner *
-- Stereo sound card
* For a list of supported DVD burners, visit the Adobe website at www.adobe.com/products/encore/systemreqs.html.
3. Update video display card drivers.
Outdated or flawed video display card drivers may incorrectly display motion video and textures, or incorrectly report their ability to display motion video or textures to Adobe Encore DVD. Contact the video display card manufacturer for the latest display drivers and driver information.
4. Select an appropriate Playback Quality setting.
You can display playback in the Encore DVD Monitor panel at either High quality, Draft quality, or Automatic quality. By default, the Monitor panel displays video at High quality; that is, it displays all the pixels of each frame of video. When Encore DVD plays back unrendered video at High quality, the video may stutter or ****. When you select Draft quality, Encore DVD always displays video at one-half resolution in the Monitor panel. When Draft quality is selected, playback is smooth but the image quality is affected. When you select Automatic quality for the Monitor panel, Encore DVD dynamically adjusts image resolution between High quality and Draft quality to best address the available system resources.
To choose the Monitor panel playback quality, select File > Preferences > General, and then select an appropriate Playback Quality setting.
5. Deselect the Automatic option in Audio/Video preferences.
1. Choose File > Preferences > Audio/Video Out.
2. Under Video Playback, deselect Automatic.
3. In order for the change in preference to take effect, you must close the Monitor panel and then reopen it.
The Automatic option is selected by default, allowing Encore DVD 2.0 to play video in a Standard Direct3D mode. When it is not selected, video plays in GDI mode.
6. Troubleshoot slideshow playback issues.
Many DVD players, both set-top and software, handle playback of slideshows differently. To conserve disc space, Encore DVD creates an MPEG I frame for each slide then assigns a duration for that frame based on the slide's duration. Many players cannot accurately display these and will instead display only a single frame of the image before reverting to a black screen for the duration of the slide.
If you are experiencing playback issues with your slideshow, be sure to play it back using a variety of players. If you determined that slideshow playback is the issue, then you can try the following workarounds to ensure the slideshow will playback correctly on all players:
Note: The following workarounds will increase the amount of space used on the DVD.
Add zooms or pans to each slide.
When you add a zoom or pan effect to a slide, Encore DVD will render the slide as a video file instead of an MPEG I frame with duration.
Create the slideshow in Premiere Pro.
You can import all of your slides into Premiere Pro and create a slideshow there, then export the file as an AVI, import it into your Encore DVD project, and add it to a timeline.
If you create the slideshow in Premiere Pro, users cannot manually advance through the slideshow the same way they can if it was created with the Encore DVD slideshow editor. However, if you add chapter points for each image, then viewers can skip ahead before the timeline automatically reaches the next image.
Create menus from each slide and link them.
By creating menus from each slide and linking them in the desired sequence, users will have complete control over when they can advance to the next image. You can set up invisible buttons with invisible highlights to give the impression that only the image is on screen, or you can include visible navigation elements for the next and previous slide, as well as any option that is available for a traditional menu.
If you create menus for each slide and link them, then you cannot have a continuous soundtrack playing throughout the slideshow. Menus can have audio but they are specific to each menu and will start from the beginning each time you access a new menu.
Intermediate troubleshooting
7. Optimize hard disks.
Optimize hard disks by defragmenting them, updating their drivers, and configuring the disk drives. These procedures improve playback speed and performance in Encore DVD. For further assistance with these tasks, contact the hardware manufacturer or an authorized repair service facility.
-- Defragment hard disks by running the Disk Defragmenter utility included with Windows or a third-party disk utility such as Symantec Norton Utilities. If you use external (non-system) disks for video, you can reformat them instead. Be aware that formatting erases all information on the disk. For instructions, see Windows Help or the documentation for the utility.
-- Update disk drivers to ensure that they aren't damaged or incompatible with the system. If a disk was formatted with a third-party disk utility, you must use the third-party disk utility for this procedure. For instructions, see the documentation that came with the utility.
8. Test digital video playback in a third-party digital video utility.
Play your video clips in an application other than Encore DVD to try to isolate the problem. If playback is problematic in an application other than Encore DVD, the problem is not with Encore DVD; troubleshoot your system or that video file.
9. Optimize Encore DVD.
For information about optimizing Encore DVD, see the Encore DVD User Guide, Online Help, and document, "Optimize performance of Encore DVD (on Windows XP)."
Aug 20, 2009 | Brady CODESOFT 7 Premier (cs7-prem-usb)
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
Locked dvd tray
Dear friend,
Press and hold stop+play button on the front panel of the dvd player more than 15 sec the player will be resetting
Mar 29, 2009 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
DVD will no eject
This is not helpful. The power is on and display is on, but no response.
Jun 20, 2007 | Zenith XBV443 DVD Player/VCR
DVD stuck
Replace the drivebay of the Bose AV3-2-1 If the drive sticks, or does not open, or If you receive an error of NO DISK, or any indicator that the disk is not properly recognized clean the lens and if still doesn?t work then the DVD drive is bad. You can actually use one for a desktop PC with a few part swappings. Check that the drive is a Toshiba SD-M1612 it is printed at the bottom of the drive bay. To use this SD-M1612 as a replacement you will simply have to swap three external parts. Remove the 3 parts from the bad Bose drive bay: Remove the 4 bottom bolts, lift cover, if the DVD bay door is locked then insert a paperclip into small hole in the front. Slide DVD tray out and remove the PC style DVD ROM tray facing. 2 clips hold it on pry them out and slide the facing up and off. Now remove the face of the drive bay. It has several clips. Save these three components (top cover, face, and tray facing) to add to the new Toshiba SD-M1612 DVD bay. Remove the old and installation is the reversed procedure above. also remove the small clear LED bezel from the new drive before adding the face. It works fantastic.
Mar 26, 2007 | Bose 3·2·1 II System
Sony DVP-NS775V DVD Player Logo
167 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
