Question about Lowrance Boating
Need cables and manuals for a LCx-19c marine gps
    Novelist:
  • 116 Answers
Click on the link to download the manual.
This can be viewed via adobe reader. Just rate the LCx-19c and then download the manual.
I hope this helps!
Posted on Jun 01, 2010
Tip
Lowrance LCX power up problem
On Lowrance LCX-19 and I would assume other LCX series units.
The T3 Transformer shorts out and when the sonar kicks in it causes the unit to go over current and will eather cause the unit to reset and start again or blow the fuse. If you have the ability you can re-wind the transformer.
The primary is 46 turns of 24awg inverter duty magnet wire,
The secondary is 164 turns of 26awg inverter duty magnet wire.
Be sure to keep the same winding direction as what you take off as it may be phase sensitive. Be sure to use mylar tape between the primary and secondary windings.
Just a note this board has very heavy power planes and is very hard to solder/de-solder on.
If you have any questions or need help you can contact me at info@jtechnicalservices.com
on Jul 20, 2010 | Lowrance LCX-19C GPS Receiver
Lcx-15ct (gps module not responding)
Before you give up on the LGC-12S you have now though, try plugging the LGC-12S right into the LCX-15CT without an extension cable. If the module not responding goes away...you just need a new extension (GPSX-25G p/n 99-46).
The power cable has a set of yellow, blue, orange, and bare data wires. If these wires short together, you can get the module not responding error.
If all that doesn't help...the LGC-12S is bad.
The LGC-12W p/n 112-06 will work with the LCX-15CT. You probably get this at many marine electronics dealers or go to lei-extras.com and buy it straight from Lowrance. They cost $229 so you might want to shop around putting that money into a whole new system altogether.
Make sure you have the latest software updates if you get the newer LGC-12W. These can be downloaded at http://www.lowrance.com/en/Downloads/Product-Software-Updates/
Let me know if you need more help.
Jul 10, 2009 | Lowrance LGC-12S GPS Receiver GPS Receiver
Need a manual for my lowrance lcx marine gps combo
You're in luck! Visit => http://www.lowrance.com/en/Downloads/Manuals/
There are 3 manuals (pdfs). The first is the manual, the next two are addendums.
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX-15MT_0133-49.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-70_add_031402.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-71_add_032802.pdf
Please leave feedback. Thanks in advance.
Jan 03, 2009 | Lowrance LCX-15MT GPS Receiver
Need manual to download
Jan 03, 2009 | Lowrance GPS
Hi i have had the lcx- 15 since 2001. i would like to update the software. plus the latest manual.
Here's the link to then manual => http://www.lowrance.com/en/Downloads/Manuals/
Here's the link to software updates page => http://www.lowrance.com/en/Downloads/Product-Software-Updates/
Here's the link to the most current software available from Lowrance =>
http://www.lowrance.com/en/Products/Marine/Large-Screen-SonarGPS-Chartplotter-Combos/LCX-15-MT/Downloads/LCX-15-MT-Software-Update-310/
Dec 07, 2008 | Lowrance LCX-15MT GPS Receiver
Turning on my Lowrance LCX 111HD fish locator creates static with my ICOM M502 VHF Marine radio.
Hello LJones0455. From your detailed attempts there are few options. Position the transducers one foward one aft. Connect the negitives of the battiers to the boat still route both positive & negitive wiring to all devices. Check the continunity of your transducers include flexing while ohming. Let me know of the results.
Oct 07, 2008 | Boating
Waypoint altitude
When asked for the altitude, enter it as 1.
Jun 11, 2008 | Lowrance LCX-19C GPS Receiver
Lowrance LCX-19C GPS Receiver Problem
It sounds like you may have to send it out for service, but before you you do there are a few things you can try.
Low voltage can cause erratic behavior. Since you already wired directly to the battery, check the plug for corrosion.
Try unplugging the transducer cable to see if the display still behaves erratically. You wont see depth readings but you should still see the screen going black. If no erratic behavior with transducer unplugged then problem is in the transducer cable or the plug. A common source of failure is at the plug because the added stress of plugging and unplugging cables can cause the socket to twist slightly which can cause a short.
Make sure you have the latest software update.
How to see if your LCX-19C is already using version 1.8.0 software:
  1. Press the MENU button twice on your LCX-19C.
  2. Select SYSTEM SETUP.
  3. Select SOFTWARE INFORMATION.
  4. The software version for your unit is located under the line that says "LCX-19C" (ex. "Version 1.8.0").
  5. If your version is the same version listed above, there is no need to download the software.
If it is lower than 1.8.0 you can download the update from this link: LCX-19C UPDATE
Copy it onto a blank MMC card and install it in your GPS. The GPS should prompt you on how to install the update.
If you need to send the unit in for service click this link: LOWRANCE SERVICE
Mar 15, 2008 | Lowrance LCX-19C GPS Receiver
Boating Logo
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
