Question about Logitech 984-000057 Pure-Fi Anywhere 2 Compact Speakers Battery for iPod and iPhone
Can I charge my device with a 12v lighter power cord? Does it matter if the power cord is 12v and the device is 12.9v? Bill Dobson.
I am looking into the same thing at the moment. apparently you can use a 12v car charger to charge this unit, you just need the correct size plug to fit. when the car is running, it generally outputs 12.3 to 12.7v through the dc plug, so it will charge the unit, just may take a little longer, best to charge while travelling to keep charge volts up. i got this information from a car battery shop.
Posted on Nov 26, 2010
Can the Garmin GPS 78s be charged in the car? Also, what is the best car holder available? Thank you.
You can purchase 12v power cords for your unit but they will not charge the units batteries. The cord will only provide power to keep the unit on. But here is a link http://www.gpscity.ca/garmin-cigarette-lighter-adapter.html.
Feb 25, 2011 | Garmin GPSMAP 78 GPS Receiver
My Magellan Roadmate doesn't work anymore when I plug it into my cigarette lighter. It says the battery is low and it is shutting down. The unit did not come with a battery charger so I am confused about...
there could be a few reasons why this is happening....
there should be a light on the car charger that comes on when you plug it in, if it isnt on when not plugged in to the gps, but while plugged in to the lighter...either the lighter fuse is blown, or the charger is defective.
if the light is on, on the charger and it still wont stay powered on, it probably has a bad usb port (very common on this model) but it could also mean the charger (if not factory) is not compaible with the unit.
another way you can try and charge it (if you determine the chargers at fault) is to hook it up to your computer via the usb cord that should of been supplied with your unit.
HERE is your manual..it will show you the differant charging options..there is also updates on that page if you need them
let me know if you need more help.
bill
Aug 17, 2010 | Magellan RoadMate 1470 GPS Receiver
Garmin street pilot 330 charging problem
Linda,
You need to check the fuse for both the car's cigar lighter AND the one in the GPS power plug (that goes into the cigar lighter outlet). Both must be good for the GPS to charge and power up.
I don't know if your friends cord worked in you car - or hers - so you're going to have to find out if it is the cord fuse or the car fuse. Since her cord worked on your GPS, start by using HER CORD connected to YOUR GPS in both cars. If it works in her car, but not in yours, check & replace your car's cigar lighter fuse. If or when it works in both cars, disconnect her cable and connect your cable to your GPS again. Connect into your cigar lighter. If it works, you're done. If it doesn't work, disassemble the plug at the end of the GPS cord (cigar lighter end) and check and replace the fuse if blown. You should be good to go at this point.
Please rate this reply if found to be helpful - good luck!
Jul 07, 2010 | Garmin StreetPilot C330 GPS Receiver
My 265wt will not power up ...
Check power in the cord. It may have a blown fuse or you lighter receptacle in your vehicle may not be working. Check for 12v power first in the outlet, then you cord.
Dec 18, 2009 | Garmin n?vi 265WT Car GPS Receiver
GPS doesnt turn on with power cord adaptor or 12v lighter socket
if you can verify that the car charger is ok, try plugging it in to your computer using the usb cable. the 1412 should charge with the usb cable. if it still doesnt turn on, try and reset the unit,little pin hole on the side.
Jun 08, 2009 | Magellan RoadMate 1412 Car GPS Receiver
DOES NOT CHARGE AFTER HOURS OF CHARGING WILL NOT TAKE ANY INFORMATION.
Confirm that it is charging, check the fuse for the cigarette lighter socket in the car you are using, check the fuse in the power cord, the tip of the cigarette lighter adapter should twist off and expose a fuse.
Hope this is of some help.
Ed
Apr 26, 2009 | GPS
Left keys in ignition overnight, turned to have interior lights on. battery is dead, cant get key out or pop trunk to get to the battery to charge it.
If you know anyone that has a portable booster, you should be able to plug the cord from the 12v outlet on the booster into the 12v (cigarette lighter or accessory charger) in the car, and get enough power to pop the trunk.
Mar 04, 2009 | 2006 Chevrolet Cobalt
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
GPS does not get charged
hi try a different dc adaptor thay are cheap enoughg
May 28, 2008 | Garmin StreetPilot C330 GPS Receiver
Charging
It should have come new with some charge on it. There is a 12V to small USB cord that comes with it. The USB port on the device is small and on the back, plug one end of the cable there and insert the other end in a cigarette lighter in auto or truck. As an option you can charge from any USB port on a computer, but you need an optional cable that goes from standard USB to small USB. This is the same cable used on a lot of digital cameras, so you may have one. Just plug it in for a few hours.
May 25, 2008 | Garmin nuvi 200W GPS Receiver
Logitech 984-000057 Pure-Fi Anywhere 2 Compact Speakers Battery for iPod and iPhone  Logo
214 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
