Question about NZXT Crafted NEMESIS ELITE (NEMESISELITEBLKNP) ATX Mid-Tower Case
Need a new power switch assembly
I Need An Entire Power Swich Assembly
  • 34 Answers
That is not hard to find at all.u will find them to be almost identical in mist computers.just remove everything like the front panel thru the side panel my friend.
Posted on Jan 25, 2011
06 srx sunroof doesnt work
Sorry Bill but you don't the tool's or knowledge to take on this job . Control module's involved.
Which one does your vehicle have ?
Power Sunroof System Components -- CF5
The power sunroof system consists of the following components:
• Front glass control module and motor assembly
• Front sunshade control module and motor assembly
• Sunroof switch
• Front glass panel
• Front sunshade
• Power supply for the front glass control module and motor assembly logic: RAP relay
• Power supply for the power sunroof system: SUNROOF MOD fuse 40 A
Power Sunroof System Components -- C3B
• Sunroof switch
• Front glass panel
• Front sunshade
• Rear sunshade control module and motor assembly
• Rear sunshade switch
• Rear sunshade
• Rear fixed glass panel
Aug 30, 2017 | 2006 Cadillac SRX
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Drivers window in pontiac montana 2002 went down and will not come back up. how do i test to see if the switch is working. The right window is functioning very well.
Most likely the window motor/regulator assembly has gone bad.Check for good fuse, if good pull out the switch and make sure you have power to it, if you do then remove door panel and test for power at motor, if u have power but motor won't work replace. Suggest replacing the regulator assembly as well because the cables often fray and cause problems as well.
Mar 17, 2010 | 2002 Pontiac Montana
What parts do i need for a broken drivers side mirror
I believe you can't get the internal parts of the mirror head. you can only buy a new mirror (just the glass) or an entire mirror head assembly.
check out...
www.burcoinc.com
www.directauto.com
hope this helps
Mar 04, 2010 | 2007 Chevrolet Tahoe
Standby power LED (CR4G1) comes on but that's it, will not start up. Replaced power supply and entire switch assembly with known good parts. Any possible explanation other than bad motherboard?
I have repaired this Model 4550. Unplug power cord FIRST. Is the Replacement Power Supply NEW? Did you plug the Power Supply in BEFORE you purchased it? Always do that BEFORE you buy it.
Oct 21, 2009 | Dell Dimension 4550 PC Desktop
Beater brush will not rotate
If you have not had this unit in for any previous service, and you are tilting it back to engage the brush with the swich on carpet mode, then I would likely suspect the switch assembly in the upper handle. The new switch and harness can be replaced but you will also need the switch knob as well. Otherwise you can get the entire upper handle. This unit has a history of the lower cable wiring harness to go bad (not an easy fix).you can tell if you tilt the vac in carpet mode and wiggle the exposed cable at the bottom rear of the vac, if it starts and stops the it is bad.
Oct 12, 2009 | Hoover U8145-900 Savvy Bagless Upright...
I have a maytag washer (model LAT9416AAE). The timer motor doesn't run. If I plug it's wires directly into an outlet, it runs fine. In the timer assembly, it apparently gets no power. Is there another...
You need a new timer assembly. Please be very care full when hard wiring your machine. it could short the machine out and also cause personal and property injury.
Jan 07, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Fuel Leak
Hi
Yes.You dop not need to replace the entire fuel assembly only the breather.
best regards savumihai71
Oct 19, 2008 | Garden
Part for sewing machine
any one have a power cord/manuel for a Janome 2049 Harmony Sewing Machine?
Jun 06, 2008 | Sewing Machines
NZXT Crafted NEMESIS ELITE (NEMESISELITEBLKNP) ATX Mid-Tower Case Logo
89 people viewed this question
Top NZXT Computers & Internet Experts
David Payne
David Payne
Are you a NZXT Computer and Internet Expert? Answer questions, earn points and help others
