Question about SanDisk Sansa e250 MP3 Player
Sansa sandisk mp3
Hi.
i downloaded videos onto my sansa sandisk mp3 player and they worked just fine yesterday, but then the mp3 player froze and before i knew all the videos were deleted, BUT the memory space is still taken up as if the videos were still there. So basically, my video folder says that it's empty, but the memory space is still taken up as if the videos are there. HELP?!?! i dont know what to do
  • 8,596 Answers
Reformat
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
How i can download videos to sansa e280
Want to put the downloaded videos onto Sansa? It's easy to enjoy video files on Sansa under help of Sansa Video Converter. It has the ability to convert downloaded videos in FLV, MP4, RMVB, MPEG, MOV to Sansa MPEG-4, H.264 video format, extract the audio track from downloaded video files and save as MP3, WMA, OGG for playback on SanDisk Sansa.
Jan 06, 2010 | SanDisk Sansa e260 MP3 Player
I have sansae200 when i copy one video clip it says it is not comeing and picturs also not comeing
How to handle pics and videos on the Sansa e200, see next link:
http://kb.sandisk.com/app/answers/detail/a_id/564/kw/media%20converter/r_id/101834
These are videos showing how to add pics and videos on the player, using the Sansa Media Converter.
Download the Sansa Media Converter:
http://mp3support.sandisk.com/sansa/SMC
Allow the download when blocked, to start downloading.
Guides for the e200 series:
e200v1:
http://mp3support.sandisk.com/downloads/um/e200v1_userguide_en.pdf
e200v2:
http://mp3support.sandisk.com/downloads/um/e200v2_userguide_en.pdf
e200r Rhapsody:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Nov 12, 2009 | SanDisk Sansa e200 MP3 Player
It froze up and now the screen is all blue
take the battery out leave out for 10 min then put back in should clear up the freeze
May 24, 2009 | SanDisk Sansa e250 MP3 Player
Videos
you need to use Youteube download software/program i forgot the exact name of the software that will work after it has been downloaded convert them to wmv , after that you can then download the sansa media covnerter on downloading the video to your sansa. you can download the sansa emdia converter at
http://www.sandisk.com/driverdownload/download.asp?driverId=184
May 05, 2008 | SanDisk Sansa e250 MP3 Player
Foze at bigining
unscrew the back, remove and replace the battery. It should restart fine.
Jan 12, 2008 | SanDisk Sansa e260 MP3 Player
Sansa problem being blacked screen please help
You can reset the player by holding the power button for 20 seconds.
It should be fine after a reset.
Best of Luck.
Oct 14, 2007 | SanDisk Sansa E280 MP3 Player
Help!
Media converter is for videos, not for music
May 19, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
