Hello, I think i have a settings problem with my hard drive, with a cd inserted, i have no sound/ volume
  • 1,472 Answers
Johnealnwick
It is possible that you just do not have setting set right. Let me know what the make and model of computer you have. As well as the version of Windows that you are running. This will better help me see what we need to do to fix your problem.
Issken
http://www.fixya.com/users/issken
Posted on Jun 01, 2010
  • 1 more comment
  • johnealnwick Jun 01, 2010
    IBM pentium 4 2.8 GIg HT CPU / windows 2000
  • Will Hartford
    Will Hartford Jun 01, 2010
    johnealnwick
    Ok I see the issue here Windows 2000 does not support playback of CD-Audio through the bus. On older computers you would use a CD Audio cable to connect the CD-ROM to the sound card. However it looks like you have an new computer running Windows 2000 so most likely you do not have the needed connection on the sound card.
    I will have to dig through my old support steps to file the options to enable the CD-Audio to go through the bus. Since you have a newer computer it should support it fine. I should beable to find the steps for you in a little bit.
    Issken
  • Will Hartford
    johnealnwick
    Here is the link to enable digital CD audio playback on your computer.
    http://www.fixya.com/support/r4998148-en...
    Let me know if you have any more problems or questions
    Issken
Hello, I own an acer aspire one ZG5 netbook, and today I got an error while trying to start it, the blue screen to be exact. Here's the error: A problem has been detected and windows has shut down to...
Hi Stefi,
An unmountable boot volume error means that the operating system cannot boot from the hard drive either because the boot files are corrupted, the hard drive is faulty or there is a problem with the cable connecting the hard drive to the computer. If you are booting your PC and come across a Blue Screen of Death stating UNMOUNTABLE_BOOT_VOLUME, don't despair.
You would need to repair the volume inorder to fix this issues.
To repair the volume, follow these steps:
  1. Start your computer by inserting the Windows startup disks or the Windows installation disk if your computer can start from the CD drive.
  2. When the Welcome to Setup screen appears, press R to select the repair option.
  3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console.
  4. Type the administrator password when you are prompted to do this.
    Note If no administrator password exists, press ENTER.
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER.
  6. At the command prompt, type exit, and then press ENTER to restart your computer.
  7. After you repair the volume, check your hardware to isolate the cause of the file system damage.
If this procedure does not work, repeat it, but type fixboot instead of chkdsk /r in step 5.
Hope this helps .
Please let me know if you need further help
Apr 12, 2012 | Acer Computers & Internet
Hi i got new hard drive in my optiplex gx520 but it comes no boot device available, what can i do?
Hello
Welcome to Fixya!!
OK, this might sound stupid to you, but i will explain anyway.
If you got a brand new HDD, you will first need to load an operating system on the drive in order for the computer to pick up the drive as a boot device. If you have done this, i am sorry for underestimating you. Now we will need to move to the second part.
If you have already done the above, and you still get that message, you will need to have a look at the Jumper settings. If this is your New primary drive, and you have another drive in the computer, you will need to set the jumper settings to Primary. This is indicated on the drive itself(SATA drives normally does not have jumper settings, it pick up Automatically).
If you use this drive with no other drive in the computer, and you still get the error message, you will need to test this drive in another computer. If you get the same message in another computer, you will need to return the drive, because there is a possibility that the drive is faulty.
Please feel free to let me know if you have any further questions.
Kind regards
Lock123
Aug 03, 2011 | Dell OptiPlex GX520 PC Desktop
When i insert a dvd into the disc drive and play it, the dvd plays but the sound that goes with it does not. i have tryed re-installing several times, no result. how can i make the sound work.
You have to check the sound settings on your PC. Don't know which O/S you have but with windows Xp, click on Start - Control panel - Sound and audio devices - Volume - Advanced. Check the CD player is included in the volume control, and not muted. If not in the volume control, click on properties and add it.
Feb 06, 2011 | Samsung Super-WriteMaster SE-S164L DVD?RW...
When I insert the usb drive into my computer it is being recognized but then when I try to access it it says please insert a disk into drive f. It's not even allowing me to format it.
Hello, sounds like your drive F: is the cd or dvd drive..or maybe even a virtual cd drive. but definitely not the usb drive. Try to right-click on all of your visible drives in turn, go down to 'properties' and see if any of them are around 4gb in size. This will be your usb drive. Are you plugging it directly into the computer or through a hub...if through a hub try plugging directly into a computer usb port till you've successfully identified the drive letter.
Regards,
nicam49
Jan 06, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
Sep 23, 2009 | Alpine CDE-102Ri CD Reciever, iPod and USB...
Volume icon in taskbar
You experience one of the following symptoms on a Windows XP-based computer:
* The Volume icon is not displayed in the notification area at the far right of the taskbar.
* When you try to add the volume control icon to the notification area, you receive the following error message: "Windows cannot display the volume control on the taskbar because the Volume Control program has not been installed. To install it use Add/Remove Programs in Control Panel. "
Therefore, you cannot start the Volume Control program and cannot adjust the volume and sound level settings of your computer.
There are two possible causes of this problem:
* The Volume icon has not been added to the notification area of your computer. (The Volume icon is not displayed automatically when you first install Windows XP.)
* The Sndvol32.exe file is damaged or missing.
Solution:
Method 1: Add the Volume icon
To add the Volume icon to the notification area of your computer, follow these steps:
1. Click Start, and then click Run.
2. Copy and paste or type the following command in the Open box, and then click OK:
mmsys.cpl
3. Click to select the Place volume icon in the taskbar check box.
4. Click OK.
If the Volume icon is displayed in the notification area of your computer, you are finished. If you cannot add the Volume icon or if you receive an error message when you try to add it, the Sndvol32.exe file might be damaged or missing. Go to method 2.
Method 2: Save a new copy of the Sndvol32.exe file on your hard disk
If the Sndvol32.exe file is damaged or missing, you must extract a new copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer's hard disk.
Prerequisites
This method requires you to have your Windows XP installation CD.
To extract a copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer’s hard disk, follow these steps:
1. Insert the Windows XP CD into your computer's CD drive or DVD drive. Press and hold the SHIFT key as you insert the CD to prevent it from starting automatically.
2. Click Start, and then click Run.
3. Copy and paste or type the following command in the Open box, and then click OK:
cmd
The command prompt opens.
4. Type the drive letter of the CD drive or DVD drive, type a colon, and then press ENTER. For example, if your computer’s CD drive is drive E, type the following, and then press ENTER:
e:
5. Copy and paste or type the following, and then press ENTER:
cd i386
6. Copy and paste or type the following, and then press ENTER:
expand sndvol32.ex_ system_root\system32\sndvol32.exe
Note: system_root is the path and folder name where the Windows system files are located on your computer. This is usually C:\Windows. If the folder that contains the Windows system files on your computer is C:\Windows, type the following, and then press ENTER:
expand sndvol32.ex_ c:\windows\system32\sndvol32.exe
Note There is a space between "ex_" and "c:\windows" in this command.
7. Type exit to exit the command prompt, and then press ENTER.
8. Verify that you can start Volume Control and that the Volume icon is displayed in the notification area (if you selected this option in method 1).
Hopefully the Volume icon is now displayed in the notification area.
Jul 18, 2009 | Computers & Internet
Loss of volume control
To use another pc and insert volume control cd , then the driver copy to a pen drive and peste it . then you can insert pen drive in your laptop and install the driver.
JEMS 4 U''''''''''''''''
Mar 08, 2009 | NeoWave PC Audio Graphic Equalizer...
Im looking for the jumper settings on a compaq motherboared. its a presario 7478
hello CAVdesert,
I don't think you ever have to change the jumper settings on the motherboard.You may need to change in few cases but otherwise, changing motherboard jumper settings is not recommended.
However, if you need to configure the jumper settings for your Hard Drive, CD/DVD Drive etc, Please refer to the following document.
Jumper Settings for the Installation of Hard Disks and CD, CDRW, and DVD Drives
Oct 12, 2008 | Compaq Computers & Internet
Windows Vista backup
hello! You completly uninstall all driver in your computer(such as USB port,sound cord etc...)! And then you insert the NEW OS with bootable CD then you can format! Try it
Jul 17, 2008 | Iomega (33090) 250 GB Hard Drive
Foxconn 6100K8MA-RS Motherboard
Hi You need to make sure that your boot sequence sets to boot from hard drive first. Also, make sure that the hard drive sequence has the hard drive enabled. If this does not work, then let me know so I can give another suggestion.
May 30, 2007 | Foxconn 6100K8MA-RS Motherboard
Computers & Internet Logo
David Payne
David Payne
