Question about Craftsman 20 Hp 42" Deck Lawn Tractor
2003 craftsman ys4500 model number917 276680 died
2003 craftsman ys4500 model number 917 276680 died and wont start got fuelt o carb and spark
Mine did same thing, need to manually adjust choke. If you raise hood and adjust your throttle you will see that when you press up to choke that it actually hits & pushed in choke. But when you back off if it is like mine the choke doesn't come off, so I manually pulled choke to off & mine started right up. I am still trying to find how or where cable came off for the choke to be adjusted by throttle lever. That is why I was on here looking for photo of engine.
Posted on Jun 30, 2010
My craftsman ys4500 21hp riding lawn mower cranks but won't fire and I have tried everything
Have you pulled a plug and checked for fire? There is a huge difference between crank and no fire or crank and no start. If you have spark, make sure air filter is clean. Next step make sure you have fuel to the carb. After that the carb would be the next step. Have it cleaned and rebuilt.
Jul 18, 2016 | Craftsman Garden
Craftsman 917 3775220
check the plug for spark make sure carb is getting gas then try spray just a little starting fluid spray into it it should start if it starts and keeps dieing rebuild carburator
Aug 16, 2014 | Garden
Craftsman ys4500
pull the fuel hose and check for fuel flow to the carby
check all safety micro swiitches
Mar 31, 2017 | Garden
I have a 3 year old ys4500, wont start
Have you tried bypassing the cut off switch, by joining the wires together
Sep 20, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
16 horse Kohler engine will trun over good, but will not fire
first check for spark then if you have spark try and spray carb cleaner or starting fluid into the carb if it fires on that you have a fuel problem keep in mind a bad safety switch can shut off the coil and also shut off the solenoid on the bottom of the carb
Jun 02, 2012 | Craftsman Garden
I changed the oil in my self propelled mower and now it wont start
If the blade control is disengaged, it will not start, engage control. Also check spark plug is connected.
May 20, 2012 | Craftsman Garden
I need a manual for a snowblower craftsman 10/30 it doesn't start,i changed the sparkplug and it doesn't chage anything,i change the oil last year,does it need to be changed this year to
Hi
Most common problem with snowblowers is clogged carb. Remove spark plug and put a tea spoon full of gas in the plug hole and try to start. If it starts for a sec that is your problem. To get a manual go to searspartsdirect.com you will need the model number to find the correct manual. Model number should start with 917.XXXXXXX.
Sam
Dec 11, 2009 | Craftsman Garden
Craftsman GT5000 W/22hp B+S surges and dies when warm
Replace the spark-plug, check the quality of the fuel(gas that is mixed or was stored more then three months is stale and wont fire correctly) make sure the fuel and air filter not clogged. If there is no change then your problem may be more technical, a nest may be restricting the govenor or you missed something with the carb and there still is debre causing it to stall.
Apr 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
What is the spark plug model number for craftsman YS4500 lawn mow
go to any auto parts store with your model info as they have a book which will tell them which spark plug is best for u.
Apr 16, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
484 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
