Question about Alvarion (929155) Modem
Hi i have modem router netgear DG634G to connect in my alvarion IDU , how to connect them
How do I connect my Netgear DGND3700 router to Fibre internet (BT infinity)
Hi there
Your Netgear router will not connect to BT Infinity directly as the built-in modem is ADSL/ADSL2+ and Fibre requires a VDSL modem as in the HomeHub5 or the BT Openreach modem. Either of these can be used with your Netgear as a subsidiary router/access point. You may now be able to get a router with a VDSL modem built in but 3 years ago it was really only available from BT and BT did not support other makes.
Hope this clarifies matters though perhaps not too helpful
Nov 08, 2014 | Network Computing Devices (NSH800S/A)...
I have internet access when I plug in the ethernet cable from the modem, but when I try to access the internet via the router it says 'connected but no internet access'. What is the problem?
I know it is very frustrating if these things do not work. I am sure that the router is not setup properly that is why it is not working. It says connected because you have a good connection from pc to the router. But the connection from your Netgear router to the modem is not working. There is a possible IP conflict between your modem and router. I suggest changing the IP address of your netgear router to 10.10.10.1 . To do this click the link below:
ftp://downloads.netgear.com/files/WNR2000_UM_24FEB09.pdf
Note: This is the manual for your router. Go to LAN TCP/IP Setup Parameters to change the router's IP address.
Apr 03, 2011 | NetGear WNR2000 Wireless Router
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
I need to reconfigure the Netgear router
There isn't really much to configure on a cable modem. If the modem is fully recognized by the cable provider (all lights are lit on the modem once connected to the cable (coax) side), then just plugging in the Netgear router's INTERNET connection directly into the cable modem will work fine. If the modem isn't properly recognized, you'll have to call your cable company and provide them the MAC address of the cable modem. The MAC is a 12 digit hexadecimal (0-9,A-F) number that should be on a sticker on the modem itself - it will be listed as six pairs of hex digits. If the cable company doesn't have that particular MAC address attached to your cable account, then it won't work.
Nov 10, 2009 | NetGear RangeMax WPN824 Wireless Router...
Netgear WGR614v7 - no internet via Alvarion ACPS-101G rev C
he cambido de maquina y para poder tener interne me pedi una contraseña cual es la contraseña
Oct 21, 2009 | Computers & Internet
Can't connect to netgear wnr 2000
conect to netgear then shut down and turn it back on.
May 27, 2009 | Acer TravelMate 5520 Notebook
ADSL support for ADSL router
No, you can't connect your router directly to your ADSL. Maybe you should try a wired router.
Nov 15, 2007 | NetGear WGR614 Wireless Router
Open Questions:
Alvarion (929155) Modem Logo
119 people viewed this question
Top Alvarion Computers & Internet Experts
boneman1975
boneman1975
Are you an Alvarion Computer and Internet Expert? Answer questions, earn points and help others
