Question about Whirlpool Heating & Cooling
I have a whirlpool acq142xao window unit it runs for about 5-10 mmminutes then the compressor kicks of for about 5 more minutes. it blows cold air just kicks on and off. i have the thermostat set at it coldest temperture. do you think my thermostats hast gone out?
oscarn
  • 110 Answers
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Posted on Sep 07, 2007
  • 230 Answers
SOURCE: dometic roof air
Sounds like the unit either has been miswired from the beginning or there is a stuck contactor relay.
The more rare scenario is that the control wire between the t-stat and the contactor is shorting to a power source causing the relay to energize. Good Luck!
Posted on Jun 23, 2008
22yooper
  • 828 Answers
SOURCE: I have a coleman/evcon heat
I would check the hig voltage power supply to the unit. Check the main breaker and make sure it is on. Check the disconnect and make sure there is power at that point to the condensing unit. The contactor will kick in from the low voltage in the control circuit.
Posted on Jul 11, 2008
motor1258
  • 6674 Answers
SOURCE: roof top motor home coleman air conditioning unit
What is outside (ambient) temperature. When was entire unit last cleaned? (evaporator coils, & condensor coils)
Posted on Aug 16, 2008
  • 37 Answers
SOURCE: york central ac keeps blowing 3amp fuse on the
sounds like you have short in the low voltge side of the electrical circuit. I would check the thermostat wires outside at the condenser. look for any bare or exposed wires from where the wire comes from the house to the condenser. the thermostat wire will be a brown wire that is run on the outside which sends a signal to the contactor to make the condenser work. common cause his rodents or happens when weed whacking around condenser. Hope this get you started.
Posted on Apr 26, 2009
Auto/On set to ON. Fan runs.
Sounds like the thermostat, the way to verify is to unplug indoor unit, remove thermostat, take pic of wiring with phone or label the wires as to the terminals. Carefully twist the yellow,(Y) Red (R) and the green (G) together. Plug the furnace back in, if the unit operates normally, replace the thermostat. I am basing this on the fact that the blower speed is changing. This could also be an anomaly within the circuit board in the furnace section, not likely though as the outside unit (condenser) is not controlled n by the indoor board unless this is a heat pump. hope this helps. D
Jul 21, 2015 | Dometic Rooftop RV Air Conditioner
Compressor will not stay on.
very good possibility that it is low on freon. If indoor unit is blowing ambient air, not cooling is happening. If this is the case and you are sure the compressor is running and then shutting off, the compressor could be overheating and the internal overload is taking out the compressor. If outdoor fan runs and compressor runs, probably cause. If capacitor is bad, unit would most likely not run that long. While unit is running, feel the large line at the condensing unit. If it is cold, and stays cold, could be something else going on. If stays warm, most likely low on freon.
Apr 19, 2010 | Intertherm P3RA-030K Air Conditioner
The electricity went off this morning and now the air conditioner is blowing warm air and I don't hear the compressor coming on its a whirlpool window unit Thank You
turn the unit off for 5-10 mins. turn thermostat to coldest setting then turn unit back on. see if the compressor kicks on in a minute . it may need to reset itself.
Jul 30, 2009 | Whirlpool Heating & Cooling
Not blowing cold air
if the compressor is running and the filter is clean could need a shot of freon
Jun 20, 2009 | Whirlpool ACQ189XM Air Conditioner
Air compressor does not kick in unless ambient temp is > 80
Do not operate low fan and maximum temperature as the coils will freeze up stopping air flow.
May 21, 2009 | Whirlpool Electronic Window Air...
Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Jul 31, 2008 | Kenmore 75101 Wall/Window Air Conditioner
Window Air conditioner pulls too many amps
Probably Seems Replace Running Capacitor Located in Component Box or Nearby Compressor
Jun 23, 2008 | Whirlpool ACQ108XL Air Conditioner
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
Heating & Cooling Logo
99 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
