Question about Toshiba TZ50V51 50" Rear Projection Television
I have a Toshiba tz50v51 Rear Projection Television. My issue is with the picture. The convergence is fine but the lines that run from left to right "squiggle". It almost seems like a bad coax cable running from my satellite receiver to the tv but when I watch a dvd I have the same problem and I have rca cables going to the tv from my dvd player. Sometimes you can hear an audible high frequency noise when the tv squiggles and the intensity of the squiggling depends on the picture. Is there a fix for this problem?
  • 10,594 Answers
Since tv is 1999 model and most likely it got problem of dried up electrolytic capacitors in EDS/NEW OSD module that is located on signal board (inputs and tuner board). Replace all capacitors on that module to solve the issue.
Capacitors replacement need soldering work with proper tools and if you feel uncomfortable doing so, ask local tv tech to hep you out.
Thanks.
Posted on Jun 01, 2010
  • solecraft Jun 02, 2010
    "The EDS/NEW OSD module on signal board(inputs & tuner board)" Is this the board that has the RCA, Coax, etc. inputs tied to it. If not is there a serial number or another way to locate this board. Is it possible to just remove that board and take it to a tv repair shop rather than bring a whole TV? Thanks again.
  • Shahid Electronics
    Shahid Electronics Jun 02, 2010
    Yes, signal board that has Coax, RCA jacks and EDS/NEW OSD board is mounted on signal board, its connection pins are soldered with circuit board, it is not plugged there so call a tech to fix it or take tv in because an expert in soldering work can take this board out without any damage.
Red and blue colors wont converge and picture is warped
Replace the convergence ICs you have 2 of them they will have PN on them STK-392-110s? Mats Electronics has them 1-800-628-1118
Sep 15, 2010 | Toshiba TZ50V51 50" Rear Projection...
The lower left corner of the picture has a red out of line convergence. It will not adjust. what can I do?
The tv have convergence problems is dead.The tv convergence board require 2 STK convergence ICS and some or all it resistors changing.To solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 14, 2010 | Toshiba TZ50V51 50" Rear Projection...
42H81 42 in. Rear Projection Television: how to move the little Xs to line up...
Go to the MENU and select PICTURE then go down to CONVERGENCE and press the up/down right/left to adjust.
May 18, 2010 | Toshiba 42H81 42" Rear Projection...
I have a toshiba tz50v51 projection tv. the red power light is on
It could either be due to the convergence Circuits ( If the Power Indicator Blinks) or the power deflection board if it doesnt blink. I have a source for parts if you would like the link.
Jun 20, 2009 | Toshiba TZ50V51 50" Rear Projection...
My tz50v51 shows a double picture
replace the 2 convergence ic stk392-110 they are located on the same boad with the divider
the transfromer that supplies the pic tubes. they cost about $20. each have any other questions my ermail is lakehickoryelectronics@yahoo.com
Feb 23, 2009 | Toshiba TZ50V51 50" Rear Projection...
Pictures and letters have a double image.
Getting into the "convergence" menu should help with this issue.
Red double picture with green and blue
convergence problem there are 2 integrated circuits inside the set needs to be replaced
Aug 25, 2008 | Toshiba TZ50V51 50" Rear Projection...
Convergence problem
You need to replace both convergence ICs number STK392-110 youcan get replacements at the following link and they provide free installation instructions with pictures so you can do the job yourself . heres the link.
http://servicemanuals.vstore.ca/
May 04, 2008 | Toshiba TZ50V51 50" Rear Projection...
CONVERGENCE PROBLEM TOSHIBA TZ50V51
convergence amp ic are bad stk329-110 and possible resisters.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Toshiba TZ50V51 50" Rear Projection...
Toshiba TZ50V51 50" Rear Projection Television Logo
61 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
