Question about E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply
E machine wont start
E- machine will not start. However I can unplug internal fan unit will boot up. I can than plug in fan unit works fine.
  • vegas2288 May 24, 2008
    Did the same thing, But now instead of a flashing green light (which I had), I now have a solid green light but the cpu will still not turn on??
  • 46 Answers
Here's something you can try: If you can borrow a computer power supply rated at 350 Watts or more from someone, do the following: Unplug your power supply from the motherboard. If it's an older model (pre-Pentium 4), there will be one wide (20-pin) white plastic connector. Along one of the long sides of the connector, there's a retaining latch. Squeeze it, and gently rock the connector from side to side along its length, while pulling up. The connector should come free. If it's a newer PC, there will be a second connector with 4 pins, and yellow and black wires. If so, squeeze its latch and just pull up on it. Next, disconnect the white power connectors from the optical drives, hard drive, and floppy drive. If the internal fan you talk about is a case fan, unplug it, too. At this point, you should be able to take all of the power cables and hold them out of the case.
Now, plug the power cables from the power supply you borrowed into all of the sockets you just vacated. The motherboard connection(s) have a little nub on one side; this lines up with the latch on the plug(s). The hard drive and optical drive connectors only fit one way. The floppy connection is wider on one long edge; this sits on a little shelf when the connector is plugged in. Plug in the case fan. Make sure the borrowed unit is not resting inside the case. Finally, plug the AC power cord into the socket on the borrowed power supply. You should now be ready to push the PC's power button. Do so.
If the PC boots fine, you have a bad/failing power supply installed in it. Sometimes they just don't have enough power to boot the motherboard when other accessories are also drawing power. If more accessories than those which came with the PC were added, this makes the problem worse.
If this works, you need to replace the original power supply. With your PC turned off and unplugged, remove the 4 screws holding the power supply to the back of the case. Lift the unit out. If you can keep the borrowed one, it's simple. Place it into your casr where you removed the original one (note the unit will fit two ways, but the screw holes only line up with one of them), line up the screw holes, and install/tighten the screws. Plug in the AC cord, and boot the PC up. If everything is okay, turn it off.
Since you're already inside the case, take some canned are and dust off the internals. Be especially sure to remove any dust between the processor's heat sink fins. Hold the processor fan with a finger to keep it from spinning.
Of course, if you CAN'T keep the borrowed unit, disconnect it as above, obtain a replacement, and repeat the installation/connection steps above.
Let me know if this works.
Posted on Apr 11, 2008
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Compressor wont start up fan in freezer stays on
        • Pull the fridge out from the wall and check to make sure it is plugged in.
        • Unplug the fridge and plug in a spare appliance to see if the outlet is working. Check the circuit breaker to the house see If the outlet is not working to see if there are any fuses that are flipped.Inspect the electrical cord for the refrigerator for damage, such as from a mouse or pet chewing on it.
    • Open the fridge to see if the light turns on. The power to the unit is fine if the light turns on, which means something else is the cause of the starting issue.
    • Turn up the thermostat on the inside of the fridge if it is set to a low setting. Turn it all the way up and listen for the condenser motor to start. Have the unit serviced by a professional if it does not May be internal problem with component
Dec 13, 2013 | Freezers
M1160n wont boot windows xp nor two internal fans
Step 1:
Lets try this...
Unplug the cpu
Step 2:
remove the battery from on the mainboard
Step 3:
press and hold the power button for 30 seconds
Step 4:
release it
Step 5:
put the battery back in, plug in and turn on , it should work fine..
Step 6:
If that fails replace the power supply..
Dec 28, 2012 | HP Media Center m1080n (PC099A#ABA) PC...
Lost password
To get around this problem, Unplug your system then remove the internal battery (Looks like a large round watch battery). Let it set for a minute or two then replace the battery and plug it in. It should start up fine now. It worked great for me, let me know how it works for you. Dan.
Nov 20, 2012 | E-Machines eMachines Desktop PC
Fujitsu Siemens CPU Fan does not spin?
First check to make certain the fan is plugged into the motherboard.
Follow the connector from the cooler unit to the m.b.
When you've located the proper plug - unplug it and then re-plug it back in, making sure it is firmly plugged in (make sure you turn off the power and unplug from the wall before doing any of this).
Then look at the fan closely and make sure it's not overly dusty or dirty.
This can clog up the fan and cause it to stop working.
If you've done all this and powered back up, and it's still not working - then you need to get a new fan.
Do not run your system without this cooling fan because you can fry your CPU.
DO NOT ATTEMPT TO OIL OR LUBE FAN THIS CAN END IN DISASTER
hope this helps
Aug 15, 2012 | Computers & Internet
Acer desktop PC locked up and now won't turn off or boot up
I've seen a similar issue on Acer Veriton 7900. When you unplug the power chord while the machine is still running the BIOS/CMOS gets bugged up. If your PC doesn't have a 3 year warranty you can clear the CMOS/BIOS. To do this, note the following...
1.) Unplug the power cord
2.) Remove the CMOS battery from the unit
[OPTIONAL] move the jumper on the mainboard to the 'clear position' It should be indicated on your mainboard.After 30 seconds move jumper back on original position
3.) Wait for 30 seconds
4.) Place CMOS battery back into its position
5.) Reconnect the power cord and attempt to power on the unit.
May 13, 2010 | Acer Computers & Internet
Lost power to the unit
I have the same fridge and found solution online. unplug it and plug it back in. worked for me and the service call was cheap.
Apr 07, 2010 | LG LSC26905TT Side by Side Refrigerator
3 beeps wont boot
it is probably a ram error,
Unplug the computer and unclip the ram and remove it, clean the ram sticks and the slot that it goes into with a small dry paintbrush. While you have the unit open clean the dust away with a small paintbrush and a hoover at the ready. If you have more than one ram stick, replace one at a time to determine if you have a problem with both or one. If it boots with one, then shut down remove plug from wall socket and then replace the other one too. If it works okay then fine, if it causes problems then you know that the other stick is bad. If it does not boot on replacing first stick, then remove it and put the other stick in and try again.
I hope this helps
Nov 15, 2008 | E-Machines eMachines Desktop PC
Samsug HT-SK5 fails with 'Protection' on display
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
May 28, 2008 | Samsung HT-SK5 System
E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply Logo
131 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
