Question about LG DLE2532W Electric Dryer
Need to check the fuse in an lg dle5932s dryer. where can i find it
  • 23 Answers
Take the top panel off by unscrewing the screws in the back there should be two. take lid off. then you will see the control board undo all the wires going to it. then there are two screws that are hold the control panel on one of the left and right. unscrew then it will kinda snap off. there open the door and unscrew the two silver screw at the bottom of the door and then the four at the top of the front panel and take the wires off then if you look down at the bottom right you will see the heater and two fused on the heating element houses and two or one on the blower housing
Posted on Jun 02, 2010
Lg dryer is overheating blowing the thermal fuse
you have an airflow problem. Check the vent hose all the way out and the outdoor vent hood.
a simple verification can be performed by disconnecting the vent hose from the dryer and see if this solves the problem.
Mar 03, 2014 | LG DLE5977 Electric Dryer
Tip
DLG5932W Service Manual
Some sites make you pay for it... but I found it FREE.
Here --> http://www.appliancefactoryparts.com/content/pdfs/129227-8.pdf
Also applies to:
DLE5911W
DLE2511W
DLE5932W
DLE5932S
DLE2532W
DLE0332W
DLG5911W
DLG2511W
DLG5932W
DLG5932S
DLG2532W
DLG0332W
on Apr 29, 2009 | LG DLG5932W Gas Dryer
My Dryer is working but it won't heat at all and so it takes longer for the clothes to dry.
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens. If the problem does not improve, you may have a defective heat coil.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | LG DLE5932S Electric Dryer
HOW DO WE INSTALL THE REPLACEMENT DRUM FOR DLE2514W
you will need to use a putty knife on the top of the dryer(about 3" in from the corners), top lifts up may want to make sure the top can rest against the wall. Here is a manual not for your model but it is the same difference, Page 37 on shows how to take apart. Good Luck Tim:
http://136.166.4.200/contents/Laundry/DLE5932/DLE5932_Service_Manual.pdf
Dec 23, 2010 | LG DLE2514 Electric Dryer
Lint been clean out but will not dry clothes after 3 or 4 cycles vent is clean
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 10, 2010 | LG DLE5932S Electric Dryer
Dryer making a louder than normal noise when drying
Possibly the roller, I would have to hear it to be sure, but if it sounds like a clunking noise, it is probably a roller, if it is more of a high pitched whine, or a sound like a penny in a vaccum you probably have something stuck in your blower.
Dec 18, 2009 | LG DLE5932S Electric Dryer
My dle 5932s LG Dryer, has a belt squeek when it starts up. What should I do first to try to fix the problem.
It sounds like the belt is slipping due to a lack of tension which would require adjustment or the belt is worn and needs to be replaced. If the belt is shiny looking, it needs to be replaced. I hope this helps to answer your question. Please be sure to rate this response. Thanks!
Aug 24, 2009 | LG DLE5932S Electric Dryer
Where do i locate the heating element on my lg dryer
no fuse unless an electronic fuse on control board, check your element continuity, then the hi-limit switch then any cycling switches for proper continuity and operation
Aug 24, 2009 | LG DLE2532W Electric Dryer
2008 LG Dryer will not heat.
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 11, 2008 | LG DLE5977 Stainless Steel Electric Dryer
No power
THese diagrams may help some
http://www.pcappliancerepair.com/model-display.php
Dryer NO Power
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a..
Hi-limit fuse that need to be checked for Continuity and replaced if bad
if you dont have a ohm meter you can hook the wires together
with a small piece of wire and by pass the themostates and hi limit fuse to see if thats the problem or not
Nov 03, 2007 | LG DLE5932W Electric Dryer
LG DLE2532W Electric Dryer Logo
132 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
