Question about Ruud UBHC Air Conditioner
Rheem air conditioner motor going in reverse
My air conditioner began overheating because the fan began to go in reverse with not very fast rotation.What would cause this? Some say motor,some say compressor and some say capacitor? Any body else have trouble like this?
  • 674 Answers
I would check the fan capacitor first. You can do that with a multimeter with the capacitor test function. I don't think the compressor would affect the fan like that. If anyone worked on the unit before it started running like that you should make sure the capacitor is connected to the start wire and not the run wire. Let me know what you find.
Posted on Jun 01, 2010
What type and size condensor fan goes in a 2 ton split system?
depends on the manufacturer. go to manufacturer internet site with model and serial numbers for parts info. if you are talking about a system other than rheem,trane,lennox. it is usually in the 1050 rpm, 220 volt,1/3 hp and you could use a rescue motor to replace it with. reversible motor.
Oct 11, 2015 | Heating & Cooling
Rheem rgua-080c blower motor not blowing strong
just asking, Is the direction of rotation correct?Or is fresh air open? Fan cage on tight?Is the fan getting the power it needsto reach and maintain proper RPM (SPEED). chk the fan switch. Some have resisters incorated to control speedilica
_
Jul 18, 2014 | Ruud Rheem Squirrel Cage Blower Wheel...
Rheem classic 80 fan motor on furnace hums will not turn on
Have you checked the capacitor? Try spinning the blower wheel by hand, if this gets the motor going you have a bad capacitor. If not, the motor will need to be replaced.
Nov 16, 2012 | Rheem Prestige 14 Series 2.0 ton 14 SEER...
Rheem air conditioner fan not working outside
with the unit off: use a stick or something safe to try to move the fan blades to be sure the motor is not seized. If it spins freely :turn the unit on and use stick to give the fan motor a "boost". if it takes off and runs you have a bad fan capacitor which is the most common cause of your problem
Sep 30, 2012 | Ruud UBHC Air Conditioner
Rheem RAKA 037 JAZ
When power is applied to the motor try spinning the fan blade with a small object such as a stick, if this gets the motor going than the capacitor is faulty and must be replaced. The capacitor is located in the outdoor unit.
Jun 21, 2012 | Heating & Cooling
My Rheem hvac condenser fan shuts off after a few minutes. I've replaced the fan motor and cap. What else should I try?
Does the compressor continue to run or does it cycle off as well? If the compressor is also cycling, it sounds like you are low on refrigerant.
If the fan is cycling off but the compressor continues to run:
(1) make sure the capacitor is wired correctly and is the correct mfd for the motor
(2) make sure the motor is going the proper direction. If it is going backwards the motor could be overheating
* if the direction is wrong, most new motors have a plug with two wires going to it in the end bell of the motor that you unplug and reverse.
Jun 21, 2011 | Heating & Cooling
Strong burning smell coming from vents and from inside rheem electric central heat. Smells like rubber burning.
You must have to open it, try to clean it..and check for some eletric cables with short circuit or bad cables burning and overheating...check the motor fan and if it has a bad AC capacitor
check the photo, and you will have an idea.v4ndre_0.jpg Good luck!
Dec 06, 2010 | Heating & Cooling
Very loud buzzing noise when unit is running
Check the contacts of your contactor for signs of overheating. Replace as necessary.
Check the tightness of the reversing valve solenoid coil if you have a reversing valve and tighten as necessary.
Check for the casing vibrating and adjust/tighten as necessary.
Check for any components including refrigerant lines rubbing along casing or bottom of unit.
Check fan blade hub and ensure blade is tight on hub.
You can disconnect the fan motor wires (tape off the leads to prevent short) and run the unit for a minute to see if the vibration exists without the fan motor running.
I hope you find these suggestions to be very helpful moving forward.
Apr 25, 2010 | Ruud Matching Split Air Conditioner
I have a rheem and the fan will not spin. Power is ok going to it.
Bad capacitor or bad fan motor. Get service tech to give you a free estimate . Russ
Jul 17, 2009 | Ruud UBHC Air Conditioner
How you speed up a fan on a rheem air handler to blow more air in my house
You can change the size of the pulleys. Either increase the fan pulley size or lower the motor pulley size. Don't go more than 1 inch at a time. You will also have to change the length of the belt. The motor runs at 1725 rpm's.
Jul 03, 2009 | Heating & Cooling
Ruud UBHC Air Conditioner Logo
171 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
