Question about Sharp MX-2300N Color Copier
Maintenance required: code dk - Sharp MX-2300N Color Copier
    Problem Solver:
  • 11 Answers
Ok so the DK code means that the Black drum counter has reached its limit
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code 07
Then you can select what you want to clear so the bk drum unit
Execute this yes then press the CA key the machine will restart and away you go
I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you.
Posted on Jul 13, 2010
3 Suggested Answers
007tech
  • 95 Answers
SOURCE: I am getting a message "maintenacne required code:dk"
DK means the black drum has reached its maintenance life - 50k copies. you need to buy an ARC26DU drum unit. The drum counter will need to be reset after its installed.
here is a starting point : http://electronics.pricegrabber.com/fax-copier-supplies/Sharp-ARC26DU-Developer-Toner-Drum-Cartridges/m12754437.html
Hope that helps.
Posted on Apr 11, 2009
  • 33 Answers
SOURCE: Maintenance Required Code DK
black drum needs replaced
Posted on Jul 21, 2010
Maintenance required: code DK
The code refers to the black drum reaching the end of its life. Sometimes you will also have a VK code that is displayed along with the DK code. This refers to the black developer life. Both drum & developer have a life of 100,000 copies which is why you tend to get both codes at the same time. The maintenance code should still allow the copier to photocopy & scan as normal, so if the copy quality is still OK then the machine should continue as usual & the codes are reset when the drum & developer are replaced.
If you have a problem printing to the copier from a PC when the maintenance codes are displayed then this can be rectified 2 ways. The 1st way is to have the parts replaced & the counters reset. The 2nd way is to turn off SNMP setting within the printer driver. If you open printers & devices & locate your printer. Right click on the printer & scroll down to printer properties half way down the list (not the properties at the bottom of the list). The third tab along the top should be Ports. Click this tab & this will show the port details of your printer. Click on configure port & this will open another box. At the bottom of the box to the left there is a tick box with SMNP enable. If the box has a tick in it, untick the box, click apply then close all the open windows. This allows the printer to print when the machine displays maintenance codes.
Hope this helps.
Dave.
Jan 29, 2016 | Sharp MX-2300N Color Copier
The screen says maintenence required code DK the machine shut down with code H2-02
The User guide Diagnosing / Troubleshooting section will have this listed - Action accordingly
Jun 26, 2015 | Office Equipment & Supplies
Sharp MX-3100; what does DK mean
h r u . DK MEANS black drum life is over need to replace black drum unit or Reset black drum unit counter.
# , * , c , *
Then you want sub code07
Feb 26, 2015 | SHARP MX-3100N
Rewiring 1968 cutlass I need color codes
The wire color code is as follows:
BLK= Black
BRN= Brown
RED= Red
ORG= Orange
YEL= Yellow
GRN= Green
BLU= Blue
GRY= Grey
WHT= White
PPL= Purple
PNK= Pink
TAN= Tan
LT BLU= Light Blue
DK BLU= Dark Blue
LT GRN= Light Green
DK GRN= Dark Green
Let me know if you require any further assistance.
Oct 20, 2010 | Oldsmobile Cutlass Cars & Trucks
Getting maintenance code DK...What is it referring to?
DK refers to the counter for the black developer powder.... a service call will be needed for this
Feb 17, 2010 | Sharp MX-2300N Color Copier
Hope that helps.
Apr 10, 2009 | Sharp AR-BC260 Color Copier
SOLID BLACK LINE FROM LEAD EDGE TO TRAIL EDGE
"dk" means the the life black drum is over. You need to replaced the drum and blade. Or you can replaced the whole drum cartridge. The line that you are getting from one of the blades, more likely from the black drum. Pull out all the drum check if there is toner on the drums.
Mar 20, 2009 | Sharp AR-BC320 All-In-One Led Printer
Sharp MX-2300N Maintenance required.code:TA
Maintenance TA is indicating the machine has reached its 100K scheduled service interval. It requires Transfer Belt Unit, Usually Black Drum & Developer, any feed rollers wornout replaced, any old firmware updated to latest version, and a general clean & check. It is reset in service mode once these parts are replaced.
Dec 23, 2008 | Sharp MX-2300N Color Copier
Sharp error codes
I have a problem with error U2-40 in photocopier sharp AR ......
I need help
Nov 21, 2007 | Office Equipment & Supplies
Sharp MX-2300N Color Copier Logo
17,041 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
